yes, High CRI is ahead at the moment,
107 Tip CRI,
95 TIP
are currently requested in the group buy thread
Are you sure about those numbers? Last time I checked, it was about 40% TIP and 60% TIP CRI. Did you add the Thumb column in with the TIP columns?
your are correct!
thanks for catching my mistake in counting the Thumb
the score is
70 Tip =40% of total
107 Tip CRI=60%
to my suprise, 53% more orders for Tip CRI than Tip… seems the High CRI option is definitely showing majority interest… glad to see Im not a High CRI minority…
ps, thanks for the heads up that The TIP CRI originally reported to use PWM is now reporting NoPWM, I hope that is accurate
I think the Nitecore change the photo and information for PWM .So finally it is not clear who is the real information.look at pictures of before and after
Not the greatest review but I found Nitecore Tip First Look/First impressions - YouTube on youtube. Does not really have much as far as beamshots go but the rest seems to be decent for a review.
which version is the one with the gray switch? Silver TIP or the Gray TIP?
looks great! Even more anxious now. I could order from Illumn and have one in 2 days!
their site says:
“PREORDER: EXPECTED SHIP TIME ~1-2 WEEKS”
Acording to nitecorestore they both have a black switch :
If you look at this picture I would say the silver TIP and the sand/tan TIP has a grey switch :
blueb8llz:
I hope not. I think it looks more sleek with the gray switch on silver.
Received mine today and its a pretty great little light. Will have a review up soon!
Look forward to your review! Any quick look? Brightness, throw, build quality?
Nitecore Tip: SEVERE Parasitic Drain in Lock-Out Mode !!
The following FIVE people in this thread are reporting short battery life when using lockout
blah9, bltkmt, YummyBacon, 1jono and 1jonowife
the lockout is controlled by the microchip and consumes battery power. This reduces the standby time to no more than a week depending on the current battery level.
thank you for confirming lockout drains the battery within a week or less.
what happens in standby?
Supposedly it’ll last for over a year.
is ‘standby’ when it is in lockout mode?
standby when unlocked allows accidental activation
standby when locked out stops accidental activation but causes fast drain
Well, if this new TIP doesn’t turn on in my pocket when unlocked, like the TUBE always did, then it’ll be OK and I’ll keep it. BUT, if it turns on in pocket, back it goes and hopefully an upgraded version emerges soon.
neal will find out :)
(maybe thats a reason why the shippment was delayed so long?)
some thoughts on the TIP
1. Great Beam!
2. High CRI option!
3. Do NOT use Lockout, it drains the battery in a few days
4. It has mode memory, so if concerned about accidental activation, consider turning off from Low.
I had this thought.
I got stuck with a flawed TUBE that turned on in the pocket. Nitecore fixed it and reissued an upgraded TUBE. .
So why should I get stuck with a flawed TIP. Should I return it and wait for the upgrade?
First TUBE, then TIP…what’s next? SHAFT?
