Nitecore Tube LED replacment
Hi,
I got nitecore tube for my kid (3yo), he loves it.
but I have a tiny problem with it: the color temperature.
Is there a suitable replacment LED that would be more warm white temperature (less than 3000K)? The perfect solution would be if I could just soldered it in place of the current led, but if I have to resolder a resistor or two thant would not be a problem.
There’s no need for high output. The low setting on tube is enough.
Anyone got anything?
Thanks
I don’t know where you are but a quick search come up with some results for you.
You will just need to trim the pins to the correct length and resolder.
I’ve done a couple of different emitter type swaps in these.
The tube has a 0.5 Watt LED in it.
A normal 5mm LED will end up very unhappy in it and probably burn up soon.
Good point, do you know a supplier for these?
Might be best to just stick an XM-L2 in there :smiley:
I bumped into them some time ago, but can’t find it back…
I swapped the LED of my Tube with a 3000K 5mm that I bought from Djozz but I don’t know if he still has some nor if if want to sell some. :
XM-L2 4C tint on the Convoy S2 and stock XM-L2 CW on the Olight S2 baton
