http://www.niwalkerlight.com/content/?266.html
The S2200, 7G10 and the TN31 just got company
Heak, both are nice!
Nice enough to burn your wallet anew?
I’ll need to invest in a Teflon coated wallet at this rate!
Spec for the BK-FA02 - the MT-G2 version has been finalised. Looks good. I want one. ![]()
Runtimes:
L6 2420 lumens 1h 34m
L5 1900 2h 3m
L4 1030 4h 14m
L3 190 33h 11m
L2 25 8 days
L1 2 42 days
Maximum output up to 2420 ANSI lumens
Constant current circuit design offers constant output
68,500 cd beam intensity / 523m beam distance
Integrated cool fins design provide better cooling
Smooth polished reflector creates maximum throw
Aircraft grade aluminum, mil-spec hard anodized for maximum wear
Toughened ultra-clear tempered glass lens with anti-reflective coating
Large cooper heat sink pad for superior thermal conductivity
Magnetic ring control switch allows you to select desired output easily
Total length: 208.5mm / Light body diameter: 51mm / Light head diameter: 80mm
Weight 680 gram without battery
Twist the front magnetic ring in clockwise direction for Strobe, Off, L1, L2, L3, L4, L5, and L6 mode
Uses four 18650 batteries for extended period runtime(able to use 2 or 3 18650s if needed) or 4, 6, and 8 CR123 primary batteries
Battery holder can be loaded into searchlight either way
Low voltage warning to alert user to recharge batteries in time(output drops to L2)
Among the 3 mt-g2 lights currently available this one looks promising on paper, like the rotary switch. I notice that its overall body design seems to blend its large 80mm head quite nicely.
Selfbuilt’s review doesn’t support this particular claim. The BK-FA01 one had flat output, the BK-FA02 did not.
Any Idea what its going for
Shipping to dealers very soon (start of June), with retail price $179.99.
A few of Selfbuilt’s comments have also been addressed - lanyard attachment point added, and the magnetic control ring made slightly wider.
It will be interesting to have this compared to Solarforce and Crelant MT-G2 models - my money is on this one being the one to get.
this is the reason i decided to go with the solarforce - its just a personal preference really - i prefer a light that pulls a constant current for the duration rather than a direct drive like taper
but i still like the design of the niwalker
[quote=jmpaul320]
[quote=Stereodude]
Same here, especially the rotary switch like the TN31’s.
It is gonna be a fight between MT-G2 hosts.
The last entrance seems more competitive.
Does niwalker uses the modders nightmare - loctite?
