[NMD] TiCu TS10 w DD 4500K 519a
Album with modding sequence:
Nice machiny and trick !
Compare 519a output to stock CSP.
I compared the momentary maximum output at the default ceiling. I used the same battery (at 3.90V). Both lights arrived with the same 50% FET firmware 0000-2024-04-20
At ceiling:
The modded TiCu w DD 4500k peaks at 315 lumens
The stock 4000K TS10 MAO peaks at 340 lumens.
The peak ceiling output of the DD4500K is 8% lower than the 4000K CSP
Great info js!!!
I’m planning on doing a similar mod in the near future so this will help a lot. :+1:
Instead of dedoming though, I’m hoping there will be enough room under the optics for sliced 519As.
And interesting that Wurkkos doesn’t use silicone wires for the aux LEDs.
I hope the mod goes smoothly for you.
I added soldering suggestions to the Album, to help avoid my pitfalls of damaging the wires insulation.
Thanks, I’ll be sure to post on the TS10 mod thread. Post yours!
