No magnifying glass?
If you don’t have a magnifying glass and you’ve got an old rifle scope laying around collecting dust, use it instead. Just turn it around and look through the objective end. I found this out when attempting a gasoline dedome. Worked like a charm.
Steve
Take apart a old camera lens and you can find some of these parts too.
Or old binoculars... I have a pair of ~35mm lenses still in the plastic housings that I use as both a loupe and a macro lens for my camera.
The lenses of zoomies I have bought all work fine as magnifying glasses. You put the flat side toward the subject, as it is usually closer to the lens than your eye is. I have a discarded one that I use, and I unscrew them from lights that are handy.
or the lenses inside those big projection TV’s, should be 3 of em
Cool tip 556. Thank you.
Anyone have one of these??
http://www.ebay.com/itm/2MP-Mega-Pixels-50X-500X-8-LED-USB-Digital-Microscope-Endoscope-Camera-Magnifier-/400564087056?pt=LH_DefaultDomain_0&hash=item5d437ae910
I’ve seen those before, I was going to get one but I realized that damping out vibration on the higher magnifications would be a real problem.
I think that thee lowest setting would be all I would need.
Might buy one after I get back form vacation to try.
I love this guy…the “Steve Irwin” of electronics :stuck_out_tongue:
Thanks for saving me $30
The $60 one looks a lot better, might try it………
And now I want an Andonstar. :slight_smile:
Thanks. I figured it was a fitting post for a budget forum. It appears there are a number of ways to see small on the cheap. That is if you’ve got some spare optics laying around. :slight_smile:
Steve
