1As are pretty awesome when de-domed, and they're only $2.40 each at Fasttech. :party:
Here's a post with wall shots of most of the different optics on both domed and de-domed LEDs: https://budgetlightforum.com/t/-/21336?page=6#comment-487411
Agreed, 2B is my favorite IF the domes have to stay on. But any other tint in the R5 bin is around double the price of the 1As, unless there's a sooper-sekrit source somewhere out there I haven't found yet.
There's lots of ways to configure it, both with the 3XP boards set up for either series or parallel LEDs, and the boards connected to each other and/or the driver also in series or parallel or both...
Actually, using four separate Nanjg drivers (one master, 3 slaves), each one running a single 3XP with the LEDs in parallel, wouldn't be a bad option. It would essentially be four single cell triples all in the same body and controlled by a single switch. My plain non-hot-rod ICR cells will push 4.2A into these triples with a 12x 7135 driver (they will not do that much into just a single LED, the triples wired in parallel need less voltage which allows more current), so four cells and four drivers and four 3XPs would work, especially if you have good IMR/INR cells.
