I got my Noctigon Triple boards in yesterday, along with 3 XP-G2 R5 2B emitters. So I tried my hand at re-flowing 3-up for the first time. Ball game was on, thought I was paying close attention but ended up putting one of the emitters on SIDEWAYS!!! Shorted out the board, exasperated I re-flowed the board again, pulled the cross emitter and checked the base to make sure everything was clear, put it back on Right and voila! My first Triple XP-G2 board. I tested it on a copper bar with a Panasonic NCR18650PD and got over 10A direct drive!
2400 lumens from a shorty L2m!! Wow!
That’s too much power, planning a small host, so I’ll use a QLite driver and put the Noctigon on top of a copper heat sink 1 1/8” long x 7/8” diameter to fill the Solarforce L2m host.
This morning, I set out to create a driver cavity in my copper sink. The piece of copper I have is already JB Welded to a .45 Long Colt cartridge casing, this so I can mount it in my cordless drill and spin it up.
And finished, showing the .45 Long Colt cartridge, yeah yeah I know it’s unorthodox but what’re ya gonna do?
Just thought I was finished. The L2m head wouldn’t go on all the way with the copper seated in the host opening, so I cut a step in the outside of the heat sink to allow it to set 1/8” deeper into the host, pretty much like a P-60 fits.
It might be just a bit too tall still, but I’ll go with it
And from the side, you can see that it sits almost flush with the top of the host with the Noctigon and emitter raised
And here it is with the Carclo 10507 clear narrow optics sitting on top
I’m out of drivers, wouldn’t you know it, so I salvaged one that had been in a wreck in the past. Got it working, added one chip to the 3 already stacked and put an AW IMR 18350 cell in the light. 4.08A for some 1300 lumens. Not too bad! ![]()
Except the driver won’t work. Runs for about 3-4 seconds and shuts off. All 3 modes run, but whichever you pick it shuts down in 3-4 seconds. I have some more Q-lites on the way, will probably use a couple more chips than I’m presently running and call it quits at some 1500 lumens. I only made the cut-out in the copper for the 1st course of chips, so if I’m going to add more than 4 it’s gotta be on the outside, never stacked 3 high before but I guess there’s a first time for everything…
Oh, did I mention all the cutting was done with an 1/8” carbide cutting tool in a dremel? ![]()
I don't think you need a real lathe. You would be very dangerous with a real one. Very nice work on that copper.
