I think you need to specify whether you want to measure the amp draw of the total light, meaning the driver circuit, springs, wires, etc… or if you want to measure just the amp draw at the emitter.
The majority of the people on BLF tend to measure the amp draw at the tail cap. So all you need is the light, the battery and then a heavy, but short loop of wire to bypass the tail cap and then use a clamp-on ammeter to measure the amperage. This is the simplest way and allows you to compare your results to most of the other members on BLF.
Check out this post:
