CRX installed an H17f driver that has built in thermal management. He also eliminated the Novatac body spring (signal wire), which made the Novatac 18350 compatible, with a bit of CRX magic.
the main differences from the CRX Triple Nova and the fw3a are battery size and UI. Both have thermal management features.
Anduril is basically a 1 mode UI, with electronic ramping in 150 steps, and memory.
H17f is a clicky UI, with up to 7 modes in each of two user groups, w programmable levels divided into 24 hops in brightness, similar to an HDS clicky or Novatac. Memory can be turned on and off.
I dont know which UI offers the lowest low, or highest high, but imo, both drivers could achieve similar brightness levels, ceteris paribus
