Does anyone know what size the Q8 uses and where I can get a replacement?
Bought a Q8 used and it came with no o-ring, no box and no spare o-rings. Wish this was specified before the purchase. Guess I’ll ask first next time…
Ask Barry to add a set of O-rings for Q8 in the Sofirn store. Rather, this will not be a problem. He’s very friendly.
45 mm OD x 1.25 thk
Would be a good idea if I hadn’t JUST received an order from them so I could have combined it.
Thank you!
@ bassoverflow:
You might order some smaller (say 44 or 43mm OD) as they may be less likely to bind-up when re-screwing the head.
The 45mm is somewhat loose fitting.
You can make your own sizes. super glue will work on rubber, not sure what to use on silicon.
https://www.ebay.com/itm/OSK-O-Ring-Splice-Kit-for-Inch-Buna-N-70-In-Case/152302312096
Definitely go for a slightly smaller size, as mine keeps sticking out its tongue when I try rescrewing it. Literally gotta go ¼-turn at a time, and make sure everything’s tucked in, else tightening it might just snip off that tongue.
I use the one on the C8 lens. 39mm x 1.5mm (42mm OD)
