i bought 3 of these units for camping trips, power outages, etc.
I did some testing and got some good results. It will run continuous for 6 to 7 hours, will light a room, RV, or Tent adequately, and recharges fully during the day in day light with the remote Solar panel placed on the roof or outside a window. Its output seems equal to a 3W - 4W LED household bulb, and i got them for $ 6 bucks each.
After i modded two of them with warm-white LEDs, i discovered the battery is a Samsung 3.7V / 3.26Wh LiPo Cell Phone pack, it is charged direct (through a Diode) from the solar cell.
I could not find any info online if these Cell Phone packs have a built in protection/charging circuit, so my concern is if it do not, will the 0.8W / 5V solar panel will over charge it, or if there is a risk of the bulb over-discharging the cell.
All cell phone batteries I’ve seen have a protection circuit in the top. The external battery contacts are part of the circuit board.
What is the size of the solar panel?
I think these units originally came with a generic low capacity lipo, but those are very sensitive to over-charging and can easily puff. So they swapped them with high density phone batteries with greater heat and voltage tolerances and a better protection circuit.
True. The ones i received work quite well, and makes an easy off-grid lighting set-up for remote cabins, cottages, RVs, Camping, extended power outages, etc. They should last a couple years or the life of the phone battery, which can be replaced quite cheaply as there are tons of cheap phone batteries available everywhere.
Got a link to the bulb please…what kind of voltage do you get from the solar panel by itself?
Could you possibly wire in one of those cheap TP4056 charge modules just in case the protection isn’t up to snuff on those batteries (even though it was mentioned that they have internal protection)
