Oh, I think only on forum like this would I get some sympathy…
So, to check things out, when I ordered my ATTINY85V from Mouser, I decided to get a CREE XML2 from them as well.
So, I have a presume real CREE-XML2-U2 from Mouser, an XML2-T6 from an AliExpress and an U3 from FastTech which I consider to be presume-unknown and possibly imitations.
Using my LUX meter for a quick test, the Mouser XML-U2 appears to start slightly lower LUX than the FT XML2-U3, but the Mouser-U2 increase just pass the FT-U3. Where as, the FT started higher than the Mouser-U2 but decreases by the second to perhaps 5% below Mouser’s U2. They both are 10-15% better than the T6 from AliExpress. T6 being less than U2/U3 is expected. U2 being more than U3 is not. So, before further testing if perhaps battery was not all fully charged…
I compared them visually, I cannot discern any visual differences. Ok, seeing no visual difference with my 30x Loupe. I even “double deck” with my 10x Loupe with the 30x Loupe, I still saw no visual differences between the three. I decided to try a USB microscope my daughter has a few years ago. After a lot of fussing around, I couldn’t get it to work on my laptop.
After removing the LED from the USB microscope, I saw some gluey stuff now stuck on my Mouser Cree. No big deal, grab a Q-tip and without thinking, I grab the “GooGone” cleaner. It usually does a very decent job cleaning glue off glass. It doesn’t work on the plastic dome of the Cree too well… Well, now, the plastic dome on the Mouser Cree looks like I did a cleaning with sand paper. I cannot even see the texture of the emitter under the sandy-dome. The Mouser-U2 now puts out about 2/3 of of the FT-U3 on the LUX meter. It was > FT just hours ago.
Sometimes, I am very good in making myself a fool… Geezze… The Mouser XML2-U2 is but days old. What a waste. Damn, what a dumb thing to do… I think the “GooGone” cleaner dissolved some plastic creating a lot of visible tiny pits…
Well, I suppose I can use a couple of ATTINY85V on stand-by… That may be an excuse for me to submit another Mouser order, and as long as I am ordering, may be I should order a replacement XML2…
