Olight I3s + 10440?
I have an Olight I3s. I have heard others use 10440 in the previous version, but not sure if it was officially suited for it.
On Olights page there is no information about the light supporting 10440.
Just to make sure I asked Olight if the I3s is compatibe with 10440 battery.
The answer I got was:
Sorry,it cannot.Thanks!
So, despite this, does anyone run 10440 in their lights? :p 0:)
If yes, how is mode spacing, and how does it seem to handle it?
i have the itp a3 eos upgraded version (xpg)
i use a 10440 imr with no issues
low and medium are the same
high is direct drive
Thanks. Im not too familiar with the various versions. Doesn't that use a different driver?
it might - i cant say since i dont own one
might want to verify with a member who has this version
it most likely is very similar though
http://www.cpfmarketplace.com/mp/showthread.php?280634-GoingGear-com-Olight-i3S-AAA-Keychain-Light-80-Lumens-CREE-XP-G2-Five-Colors&p=4711808&viewfull=1#post4711808
you should be ok
It’s not officially supported, but all versions including the original iTP versions will unofficially support a 10440. I have tried the I3S personally.
Thanks for the info guys.
If anyone have done any long term testing. Or tried it on high for a long time, it would be nice to know. Or just hear what people think about 10440 vs nimh in the light.
I used it for a couple months that way before I got bored and went back to an Eneloop. The I3S sits in my emergency bag now which I think it is perfect for because of the efficient circuit, long run time on low and hidden strobe.
EDIT: I never used it on high for more than a minute or so with a 10440, though one of the kids went in the backyard with it and came back about 5 minutes later saying “there’s something wrong with your flashlight—it’s too hot to hold” haha.
J) Perfect!
:love:
on a fresh cell (4.2v) it will get hot FAST - 30 sec - 1 min
when the cell is around 3.3-3.7v its safe to run for about 2-3 mins max
you will feel the light warming up, if its uncomfortable to hold, switch to medium :slight_smile:
If its uncomfortable to hold, I normally change to the other hand. :p
Ill be testing it with Nichia 219 first. With that emitter, peak with fresh battery will probably not be more than 2A. With the sag of these small batteries, its probably down to 1,5A max after 1 minute. And that is "best case" if its direct drive on high.
Started a new thread on where to buy quality batteries as I am looking for 16340s too.
For 16340s I’ve been using the EagleTac brand from GoingGear.
For sure these lights can take more heat than we usually give them credit for. I have an XM-L headlamp that gets too hot for me to comfortably touch. On several occasions it has been left on like this for 2+ hours straight (holds 2 x 18650)… I use it several times each week and it is still working fine. I can imagine that I am probably decreasing the service life by some amount, but probably not enough to matter much to me.
The real danger in these small lights running Li-ion may not be the overall temperature rise, but the excessive temperature experienced by one or more small components that cannot effectively transfer that heat.
I have (accidentaly) run a P60 light up to 80 degree Celsius. I have had an MT-G2 so hot that Im pretty sure it got slightly "de-soldiered" from the MCPCB.
Emitter heat/life does not concern me as long as the emitter is nicely attached to a flashlight. :D Its not like these small 10440 cells will maintain high current for long anyway. And its not like they are capable of over-driving most emitters much.
Accidentally melting stuff or killing driver circuits that can not be easily replaced is more of a concern. :p
btw, there is a reason you have several modes in most flashlights.
What you end up with is….High-Turbo-LowLow….no medium, it gets hot on both high settings. Low is very low but too bright for moonlight. I carry both batteries (Efest IMR & Eneloop) covers about everything. I used to use Ultrafire 10440s and they limited total output but made it maybe a little more useable. Of course, brighter is better, right? Efest is brighter….it gets hot Quickly on either high setting! Hope this helps…
That is useful information tallboybass.
Thanks. :)
I tried once using cheap blue ultrafire and like other only on high that got real boost…
the heat built up fast…
