Among all types of lanterns, camping ones are my favorite. I have some kind of hard-to-explain affection for them.
Though Olight do really cool stuff, which i totally like (besides their tendecy to stick to propriatary batteries) they`ve ignored this sort of light source.
Obviously, the Olight O bulb, their pen test, came out quite unconvincing and the manufacturer folded hands after the bulb was released. Strange, competitors have produced a lot of camping lamps. And even if there were also some frankly strange model among them , this did not make the competitors to give up …
Well, finally, Olight released their own camping lamp with good design and serious brightness. Lets take a look is it worth buying or not.
➤You can buy Olight Olantern at AMAZON (seller also gives Olight I1R 2 EOS keylight as a gift when buy Olantern)
Light source: LED Warm / White with 360 lumens.
360 ° light distribution
*Batteries: *4 pcs. Li-ion 3.7 V. 18500 1900 mAh.
*USB charging current: *5 Volts / 1.5 Amp.
*USB charging time: *7 hours.
LED lighting module changes to white and yellow
Body: PC polycarbonate and thermoplastic elastomer
Waterproof: IPX-7
Shockproof: 1.5 meters
Dimensions: 136.3 mm x 66 mm
Weight: 347 g.
PACKAGE AND APPEARANCE
Excellent quality packaging with good printing.
There is box with the rest of the kit: namely an additional LED candlestick, charging cable and manual. Omg, they`ve even added a bag with a wet napkin to wipe the glass.
Olight Olantern is larger than some other camping lamps, as well as smaller than others. The size is reasonable for 4 * 18500 battries and a classic lamp design,
The lamp is not compact and I think that, due to its size, it will not be the good choice for tourism, where, as you know, people fight for every gram and centimeter they have to carry on themselves.
To be fair, OLantern is actually quite compact and lightweight thing alive. It’s just that all the other models are to the right (Nitecore LR50, Fenix CL25R and super-budget hit from Mingray) are very small.
This LED camping lamp is 100% retro-designed. The view is pleasant and nostalgic. The molding of plastic, and plastic itself are of high quality. It would be surprising to expect something else from Olight.
There are three color options.
The Suspension hook partially covers lamp shade when folded, acting as a sort of bumper. It does not affect the passage of light in any way.
I think it would be great to cram some kind of magnet inside, or at least add a regular round magnet with a hook to the kit as an adapter for hanging to smooth metal surfaces.
There are two LED modules: a brightner main white light and an additional one for the warm candle mode. This module is also stylized like small candle. For me idea of TWO replaceable modules is REALLY user-unfriendly .
You need to unscrew the transparent shade to change them. There is an inverted reflector cone in its upper part. The plastic is thick. There is an O-ring. Shade curls up quite tightly.
This is how it looks live.
The lamp is controlled by a single backlit button. The button is flat, the stroke is shallow. You can be 100% sure that you will not be able to feel it blindly, you will have to press the whole lamp in a circle. For a camping lamp, this is a small problem, but why not somehow highlight the button and \ or its location, since the plastic body allows everything. Or at least turn on the backlight for the button in the beacon mode?
There is a usual Olight magnetic charging contact at the bottom of the lamp . It is slightly raised, so that the lamp stands firmly during recharging. look at these three holes. They hide passages for three long screws. I unscrewed them, but since the bottom is sealed, it gave me nothing.
That, in fact, is all. The appearance is pleasant. I have questions about the general logic of the constructive (about it in general impressions), but also the appearance and build quality at the usual high Olight level.
UI
good and logical. I consider it to be as best as it could be for average user.
On / Off: press the button once to turn on / off the flashlight.
Operating modes: when the flashlight is on, press and hold the button to cycle through modes
Minimum White Light: To directly access the minimum white light, press and hold the button for less than 2 seconds when the flashlight is off. Good idea for camping lanter. Fenix and Nitecore models totally ignore this feature. And you have to turn flashlight off in lowest mode in order not to get blinded when you turn camping lanter on at night.
Lock / Unlock: To enter lock mode, press and hold the button for more than 2 seconds, after a short flash, the flashlight will enter lock mode. In lockout mode, if you press the button for less than 2 seconds, the flashlight will flash briefly in the minimum white light mode. To exit the blocking mode, press and hold the button for more than 2 seconds until the flashlight turns on at minimum mode.
HOW OLIGHT OLANTERN ILLUMINATES
I, to put it mildly, critically look at the advantag of using 4 * 18500 batteries instead of 18650. Such decision let to save just 15mm of length (nothgin regarding overall size), but decreased possible runtime almost twice. Hey, Olight, try 4*10180 next time.
But if I don’t like idea of 4*18500, then the real runtime of Olight Olantern left me an extremely positive impression. But, damn, again, it could be so much longer!
I was especially pleased with two features:
a) the lamp shines at maximum brightness without stepdown (I do not take into account the symbolic one). That is giant advantates comparing to other rival camping lanterns.
The declared 360 lumens are achievable for a small number of direct competitors of Olight as a brand: the antique and already inaccessible Fenix CL25R or the fresh Nitecore LR50. But in their case it will be an short turbo mode. Whereas O Lantern allows you to make full use of its maximum brightness. Ah, by the way, expensive and much larger Fenix CL30R, will step down exactly at this brightness after a short run in the turbo, .
b) OLantern fully supports external power supply! The most common 10000mah power bank (for Olight Olantern review used a good and inexpensive external battery Romoss Sense 4 , i reviewed it and it has honest capacity) will allow you to count on a full-fledged work from evening to morning. That is unbeliavably nice feature, i`ve been waiting for years.
Here, by the way, magnetic charging (i really dont like them) reveals it`s advantages. If you drop the flashlight or just decide to pick it up and go somewhere, then you will not need to look for the charging connector or worry about its safety (in case lanter hit ground).
Although, however, I would still prefer type-C
Yes, once again we met a sitation when flashlight manufacturer lies in specification.
Olight claims that O Lantern should shine for 20 hours in MID mode. I got 21 hours. High mode lasts longer them promised as well.
One more point. As you can see on runtime chart, the light turns off completely without switching to the mode below. In fact, after turning it off, you can turn on the lamp again (about 2 minutes in HIGHn or 5-7 extra minutes in MID). That is, there will be some kind of reserve in order to at least connect the lamp to charging.
And 360 lumens of maximum brightness is really enough for you. Moreover, even an average mode of 120 lumens is quite enough for you to light up a gazebo or a medium-sized room quite well (which is confirmed by real user reviews at Amazon). I would not read books in MID mode to I save my eyesight. But after a quick adaptation of the eye, you will not feel a lack of brightness. Well, you can already read or play cards when Olantern is in HIGH mode. Although it all depends on your position in relation to the lamp, the size of the illuminated place and the presence of walls. There are a lot of variables.
I would consider the Sofirn BLF LT1, which is perfect for me in everything, to be a serious competitor in terms of really bright camping lamps. Well, except for the size and weight, except that - here you pay off the all-metal body with 4X18650. Let me remind you that this lamp also supports stepless adjustment of the color temperature and brightness.
It can be seen that Olantern is dimmer than LT1 at maximum, but still is quite bright. Again, it`s 360 lumens HIGH mode is aroumd short lasting TURBO of literally any other camping lanter you can find on market.
There is a small blind spot below lantern. But since the top of the lamp is in the shape of an inverted cone, blind spot it will dissipate if you just raise the lamp.
It is clear that you should not expect any serious light in the candle mode. This is the perfect candle to create a cozy atmosphere or just to use for night travel. In order not to crash into the walls, this light is enough for you, plus I expect that such brightness and low color temperature will not harm both night vision and the production of the sleep hormone (melatonin is not very friendly with the blue spectrum of light).
OVERALL IMPRESSIONS
Fortunately, I have the opportunity to compare the Olantern to many other camping lights. And I, perhaps, will start with the fact that I did not like it, so that later I can polish this negative with a dose of positive impressions.
Olight chose two technical solutions, which, I believe, have no basis other than clear marketing.
1) I see no technical limitations that would not allow to increase the diameter of the replaceable module to accommodate LEDs for both the main and additional light (and even add red one). Both latter ones have a symbolic brightness and probably requires only one single LED.
This option excludes:
the need to take off-put on the plafond
high probability to loose any of replaceable modules
the need to carry both modules with you and generally remember where they are
the need to change modules in the middle of the night if you need more lumens than candle module can provide you with.
2) Again, for those who are not in the know, 18500 battery differs from common 18650 batteries by 15 (!) millimeters in length. And somewhere around 1300mah capacity. It is for the sake of such savings in size that the manufacturer deprived the user of 1300 * 4 = 5200mah capacity. That is, it took away the potential 70% of the capacity. Bravo!
3) I don’t have any problems with camping lanterns with built-in rechargeable batteries. But I’m not at all a fan of any proprietary charging connectors in any form. If even Olait 18650 battery can be charged in an external charger if the built-in charging wire is lost, then in the case of OLantern, the loss or breakage of the wire nullifies all possibilities to use the lamp. In fairness, if you have any other olight lights (and they almost all have a similar charging connector), then there is no issua at all.
Now for the good, there is also something to say.
I love the design and styling as well as the overall build quality.
The light is decent, with a remarkable maximum brightness and a good modes set. Well, and, most importantly, the ability to work at maximum bightness for a long time (thoug not that long as could with 4*18650) Light is around 4700-5000k which is definetaly good. I would prefer 4000K-4500K for camping comfort. And even with a “lamp” body, this warm light would look completely organic. But this moment is quite subjective and I can say what and how this light is 1005 OK.
A big, big advantage is the ability to work directly while being charged. Taking into account the fact that for most situations you will need medium mode, this largely negates the runtime limit of 18500 battery pack.
Candle mode is a pleasant solution that maximizes the cozyness and comfort. You will not have enough brightness for reading, but this is exactly what you need for some cozy gatherings in the twilight. Drink and discuss goode olde times when grass was greener and Stalin gave you some vodka before sing lullabye.
The result is a rather ambiguous solution. Olantern is a camping lamp and I am 100% sure that it is good for the usual camping and summer vacation, as well as weekend outdoor rest, where this lamp will reveal its strengths.
But Olantern will not be practical for tourism primarily due to its size. Built-in batteries, magnetic native charging and replaceable LED modules will clearly interfere here. Personally, I would choose the same Nitecore LR50 for real tourism. Compact, with opportunity to choose direction of light and use this lantern to charge your 18650.
The amount of negativity in the first part of the overall impressions is largely due to the experience of using another Sofirn LT1 camping lamp. You could see it at the beginning of Olight Olantern review, pic with the size comparison at the beginning of the review. LT1 is much larger, heavier and lacks the minimal design finesse. But there is the most convenient UI with access to everything in general, replaceable batteries with type-C charging and 600 lumens of turbo mode with smooth adjustment of not only brightness in general, but also color temperature.
After using such a convenient camping light, you start to look at it as a probe store to compare with.
So I think it would be fair to balance my impressions with a number of overwhelmingly positive reviews from on Amazon.
I think that the flashlight should definitely please Olight fans - the presence of other Olight flashlights removes the main potential problem for me , being bound to Olight charging cable. It is because of the latter that I think that other users should weigh the pros and cons. Perhaps a model with the usual charging connector will be a more justified choice. The same Nitecore LR50 or Sofirn LT1, if we talk about Olight rivals. I’m not sure if I’m ready to recommend any of the current Fenix models, there is nothing similar in size and overall battery capacity. And they are not that good in light stabization.
