Just received the S1 Mini that I bought from olight_direct on Ebay. It was shipped from Olightworld.com in Georgia and arrived in 2 days. I have had an S Mini for a few weeks, that I bought from Illumn.com on sale 30% off with code blacknovember.
some first impressions:
The S1 Mini has a Low Battery Indicator, the S Mini does not.
Olight S1 Mini Low Battery Indicator
Ran the Olight S1 Mini on High of 271 lumens on my meter until it stepped down to Medium of 57 Lumens, at which time the Red LED on the power switch turned on.
I removed the battery and after it recovered for a few seconds, it read 3.39 Volts on my meter.
Plugged in the USB charger:
2 1/2 hours later :
After recharging the battery the Red indicator LED on the power button did not come on any more
Conclusion, Red LED in the power switch comes on below 3.4 volts. At that voltage, Medium mode still works, but not high.
Carry Weight:
The 0Light USB battery weighs 18 grams
The empty 0Light S1 Mini weights just 20 grams. Total 38 grams.
The empty Copper 0Light S Mini weights 51 grams. Total 69 grams
Modes:
0Light S1 Mini 0.5 - 15.9 - 57.1 - 260 - 464
W minus green @ 57.8% 0.3 - 9 - 34 - 158 - 275
S Mini Cu 0.4 - 8.8 - 69 - 486
W 1/2 minus green @ 72% =0.3 - 6 - 50 - 350
Note the S1 Mini has a High mode that can be reached separately from Turbo. The S Mini goes form Medium to Turbo, there is no direct access to high mode until the light steps down.
PWM and or Constant Current Flicker test w iPhone 8:
And video version
I can not see dots when waving the light with my hand. The camera is more sensitive than my eyes.
Summary First Impressions
the S1 Mini feels very lightweight compared to the Copper S Mini. There is a 31 gram difference.
the tint of the S1 Mini and S Mini are both very green, more testing to demonstrate CRI differences and tint differences to follow.
the S1 mini cycles low medium high, I like that better than the S Mini that cycles low medium Turbo. Both have last mode memory, w direct access to moonlight and turbo and strobe.
