I can’t find anything in plain text but the text in the pictures suggests that the charging dock detects (and not charges) non-supported batteries like NiMH and Alkaline. So the light accepts pretty much all sorts of batteries, but the charger will only accept 14500 LiIons.
I can’t find any literature about its charging system. Anyway, you say “the charger (assuming I plug the the USB cable for it to a USB charger) will only accept 14500s”, if it’s true then don’t you think it should be described officially as such? If will be quite dangerous when the loaded cell is an AA if that is so.
Or perhaps the charging dock detects the loaded cell then adjusts the incoming voltage as needed?
I think olight designed this as a plug and play device. That is why the battery Is built in the device. Being rechargeable, nonflashers would rarely attempt to replace the battery inside. It is not foolproof though
