OrcaTorch D830 high lighting diving flashlight is in promotion from 1st~31st May 2016!
Promotion details:https://budgetlightforum.com/t/-/39633
As for most divers, diving light only accounts for small portion in a huge diving equipment market. The main difference of choosing a LED flashlight lies in brightness and appearance, so spending less effort on the reliable dive light brightness is better. However, small thing lead to success and details to perfection. OrcaTorch always holds on the principle of details controlling to provide you with reliable underwater lighting products in order to reduce you concern on choosing and using them. OrcaTorch D830 high-strength handheld diving light is a typical case!
1 Simple and one-handed operation
OrcaTorch D830 has 133m length and 38mm tube diameter in the tube, so one hand can hold it and easily operate head magnetic sliding switch. Using air-craft T6061 alumium material and latest diamond grade seawater-corrosion-resistance hard anodized finish which is thicker and denser than normal Premium Type III military hard anodization, making the light surface as tough as diamond to protect the light from seawater corrosion, leaving a comfortable felling.
2 Magnetic sliding switch.
Head magnetic sliding switch can not only help divers freely to change output gear, control switch and also operate flashlight by one hand. Designed 5mm safe distance, magnetic sliding switch can effectively avoid wrong operation underwater to safely and correctly choose high, middle and low these three output model.
3 Huge heat radiating groove designing in the head
Adopting air-craft grade aluminum thick light body can formally absorb flashlight heat. OrcaTorch D830 adds 4 heat radiating grooves in order to expand heat radiating area and control it’s working temperature and working life.
4 CREE LED
OrcaTorch D830 adopts the best LED brand---USA CREE, CREE LED working life can reach 50,000 hours. In order to balance the flashlight brightness and runtime, OrcaTorch engineers adopt CREE XM-L2(U4) LED to reach the max output 800 lumens and nearly 3 hours’ runtime by using high grade model.
5 Dry batteries supply energy.
OrcaTorch D830 does not use the common design of rechargeable batteries, but uses international general 3*AA battery to supply energy. You will never worry about charging problems and can add power light supply in any place and in any time. AA battery has a small size, light weight and is easy carried. Battery compartments used for assembly AA have plus and minus indicative mark, no worries about thinking how to correctly assembling battery. Diving light drive has imputed meter protection procedure, so even reversing batteries can’t damage the flashlight.
OrcaTorch D830 Diving Flashlight, one of the best solutions for safe and reliable diving lighting.
Looks good.
But could a li ion be used if one wants to?
Oh,that’s a question.it can’t :frowning: .
The cell holder looked a bit short, but one never knows :wink:
And no need for sad face, this is just a very safe light where people do not need to learn good practives as they ought to when using Li Ion so I get the idea behind it :wink:
Just if you ever want to make a new verion of it, make the tube a little longer so mad flashoholics like us can install a 26650 or 18650.
i’m confused about your promotion 2. the picture shows “buy 1 get 1 free” but the text detail only talks about a free wrist strap. so, for the price of one D520 at $59.95, do you get 2 D520 lights and 2 wrist straps?
“buy 1 get 1 free” should mean buy one D520, get one D520 for free.
Thanks for the advice.I will remark it on the previous post.
