wrong this depends mostly what type of driver is used
Best is here to use sort of linear or Buck drivers to set a fixed 7A per LED
the LEDs run on very low voltage, so a buck driver will even produce less heat than linear
7Ax3x3.2V → 67W electrical consumption
about 20% leaves as light so ab bit over 50W heat
if you DD that on a soft cell like NCR18650 with not bridged springs the total current will be a lot lower than 21A
