tatasal
(tatasal)
1
Take a look at this: 405Kcd !
Sheez…does that thing have an optional recoil pad?
kevind43
(kevind43)
3
buckle your seat belt and hold on tight.
alex21
(alex21)
6
I’ll buy it as soon as I can find a practical application for it.
… have to admit tho it does look pretty darn uber cool
jmpaul320
(jmpaul320)
7
Practical applications are as follows:
Slicing limbs off zombies
De-railing freight trains
Illuminating wildlife 3/4 of a mile away and watching them get confused
Suncoaster
(Suncoaster)
8
A Zeppelin hunter !
This must be the king of throw, now.
jmpaul320
(jmpaul320)
9
i agree - even my vpt3 with sbt90/aspheric combo might not even be able to take it down
well see when it gets here!
ChibiM
(ChibiM)
10
Does anyone know HOW they got to this point?
Would be interesting to learn how they did it.
It doesnt look like they have changed the reflector for example…
I wonder how!
jmpaul320
(jmpaul320)
11
xpg2 direct mount to copper… its probably driven to 2-3 amps I would guess as well
Kevin (lambda) also did a varapower with the xpg2 direct mount to copper at close to 3a with good results
the xpg2 has a smaller die than the xml - aka a smaller more intense beam with less of the lumens going into the spill
And remember, too, your only getting 2000hrs runtime out of the LED. So your going to have a much shorter life than normal.
ChibiM
(ChibiM)
13
Okay… if that`s true, it doesn`t look too difficult then
(though I think soldering it onto copper could be a bit difficult, personally)
jmpaul320
(jmpaul320)
14
it sounds like it was a pain to get the led to focus properly from his description
scaru
(scaru)
16
How do you guys know it was a XP-G2? I don't think it said that anywhere, either way: I want!!!
tatasal
(tatasal)
17
http://www.onestopthrowshop.com/OSTS-TN31mb-TN31mb.htm
It says so!
I’ve been dodging the TN31 from the original $232, $139 with Ti, $130, $110, but not this time….ordered one.
rikr
(rikr)
18
Here it says it … The light now sports an XPG2 and direct to copper mounting.
ersecu
(ersecu)
19
here is a tn31 with xpg-2 on copper with ~4a
Also etwas geht immer, die Mosfets können fast immer 20-60Ampere schalten.
Das Problem ist oftmals die Sättigung der Spulen die irgendwann eintritt, dann nimmt der Treiber zwar viel Strom auf aber an der Led wird es nicht mehr (Wirkungsgrad sinkt...
the vpt has about 200k lux
When you click the link it’s right towards the top(4th sentence).
