hello, if you broke your RD device, or you want to repair it but do not know how to do it, you can contact us for help even you do not order them in our shop, it is ok
hello, a customer ask me that if RD6030-max set is much better than RD6030 normal set, actually they have almost same performanfce, RD6030-Max just has bigger screen, USB-C port, and silicone sleeve
hello, a customer told me that he likes the design of RD series power supply, but he need over 100V DC output, since we do not have such model, he asks if he can connect 2 devices in series to get 120V output, for this we do not add protection, so that we do not allow operation in this way
hello, a customer asks me that if set 10V output, get 9.99V output, is it normal or not? you can check the product page, there is technical parameter, output voltage accuracy shows allowed error range, so in this range, there is no problem
hello, if you find the fuse warning prompts and red led lights near the fuse, then this fuse should be burned, you can contact after sell service, we can help you check and solve, by the way, do use green terminal for battery charging
hello, a customer asks me that, if he turns on the auto output, can this RD6030 continue to charge the battery when input power is disconnected and recover, for battery charging terminal, it has protecction, it needs to detect if the battery is connected well, and then you turn on the output manually for safety reason
hello, we talk about the auto output function of RD power supply when power on before, a customer ask me if DPS5020 has similar function, yes turn on the S-INI and it is ok
hello, our company will be moving to a new address, it may takes 1 week, normally there should not be big problem for sending the orders, if you need large quantity which we need to produce, it may delay, please notice that, later we will make video about our new company
When will the price return to ‘Normal’?
hello, the first release promotion already ends, now since the cost on aliexpress is higher, so that price is higher, if you need it, you can put it into cart and wait a sale
Do you sell on other channels than Ali?
we also have alibaba, there should be more shipping ways, but shipping time will be different according to the shipping fee
hello, in this video, a customer return the device back, he said power on it will cause the circuit breaker to trip, we power on it, front panel has no problem and can output normally, we open the box, find some insect bodies, one of them short the pins of a MOSFET, we do not find any damaged chips, after cleaning the product, it can work normally.
hello, a customer ask me that can RD6030 output over 30A when using lower voltage, it cannot do it, you can see it cannot set higher current, and if you enter like 40A directly, it will show set error, at any voltage it can always output 30A max https://www.aliexpress.com/item/1005006881009078.html
https://youtube.com/shorts/_wjayJWRIi4
hello, we get a RD6030 for repair, when power on, the screen cannot light, power button flashing, power board is ok after check, problem is on mainboard, we find microcontroller is damaged, after replacing it we need write in program, calibrate readings, normally if the power board is ok, microcontroller is damaged, it should be input voltage touches main board directly
hello, a customer ask me that he add a rocker switch between RK6006 and input PSU, when turn on the switch, it is always burned, why?
it is because when connect AC input, there is always 68V at the PSU output(our PSU, yours may different), when you turn on the switch, it will power on RK6006, especially these capacitors, then there will be 30 40A even 50A instant current, your rocker switch may just 10A 16A, so that it is easily broken
Please consider adding remote sense to the high current models, it’s available on the RD6006P but it’s really at high current that this feature is the most needed. I really wish my RD6030 had this.
for this we are designing more convenient method, we put it on RD6006P for test, but if it is sassembled, not convenient to use, so that we are considering that
RD series power supply, super easy to use, even for beginners.
just connect input power, connect the load, and quick set the output voltage and current, press the ON/OFF and it is OK
https://ko.aliexpress.com/item/1005010130354965.html
hello, when you get S400/S800 case, you find each side there are only 2 screws installed, but no screw is missing, these 4 screws are used to fix the case, so that it will not shake in the package, there are more screws in accessory bag, you can use it
https://ko.aliexpress.com/item/1005005604512352.html
