Out of the Shadows
Hello,
I want to buy a flashlight that takes some kind of batteries, can anyone help?
Just kidding!
Hi all, I’ve been lurking here for a while now and thought it’s about time to come out into the light!
I have a small but reasonable collection of lights, most of which i have modified in some way or another, usually just little tweaks.
The first thing i do when i get a new light is to take it apart because i like to see how things are put together and if it can be improved to my liking in some way.
This does not always go as planned…
About my addiction:
It all started over a year ago when my new Nine led TurboStar 3xAAA camping torch from the far east failed miserably on the first night of use. It started off with 9 fairly bright (I thought at the time compared to my maglite solitaire) 5mm leds, but every hour that passed, another one of them would fail.
Shaking, hitting and swearing at it only made it worse. There was like two LED’s left working dimly the next night when I turned it on.
That was my first flashlight that could fly, briefly, before landing in the pond.
I obviously needed a better flashlight for future outings and my internet search led me to the unusual looking sipik sk68 3 mode ultrafire clone with zoom function? which cost all of £1.69 winning bid with free shipping. Can’t lose.
I didn’t expect much so when it arrived and i put an energizer inside it and turned it on the first time, bezel facing me, i thought F&%K ME! what’s the LED in this thing!!?
Then I read some info that it could go even brighter on something called a 14500 3.7v lithium ion battery… brighter than it already is… really?
Hmm, got to get some of those I thought.
I did the usual drill that i suspect most newbies go through, ordered some ShitFire highest capacity mAh 14500 batteries that i could find and the single bay FireStarter charger that i now know were total crap but they worked and WOW, what a boost to that tiny lights output for ten minutes or so on max!
I was seriously impressed with the output and throw capabilities of this light.
Not so much the runtime but i was willing to sacrifice that for the lumens…
This got me searching for other bigger lights because if the sipik was rated 200lm then imagine what the 1200 or 2000lm lights would be like…
I was hooked and on a quest but didn’t know it at the time.
Needless to say i’ve had a few “2000-4000” lumen chinese offerings before i became more informed (thanks guys) and started to buy more quality lights.
I think most of us start off as Max Lumen hunters and the tint/CRI beam profile white wall artifact hunting thing comes in after a while when you pick up your first NW emitter and see the difference although it can be a struggle to go for one at first because of the slightly lower lumens, right?
Now i realise it’s not about max output but max application of usefulness at any given time.
(No point only having your SRK with you when map reading)
I decided to find out more about LED’s and batteries etc and found this great friendly place…
(And the other side too)
Then i saw a flashlight with Tritium vials installed. Best idea ever i thought! You can find your flashlight in the dark when it’s switched off. Pure Logic…
And more cash to spend…
I have since been acquiring various different small flashlights and modding them as best i can.
(oh what i would do for a small lathe, press drill and cnc machine!)
The Dremmel will have to do for now.
I have learned so much while reading all your posts.
I would like to thank all the the people that give such useful
information freely, especially the reviewers, modders and of course sb56637.
Anyone still reading this?;
We all love pics so where is the best place to host said images?
As this is the first time i have taken part in a forum and would like to contribute too.
Here’s my list of flashlights & little mods so far:
Aleto T6 XML Zoomie - (GITD around LED)
Aurora SH-034 - (Sanded to brushed finish)
BlackShadow Fire - (GITD around LED)
BlackShadow Queen - (With 2 Orange 6x2mm trits by GITD switch and Lockout Disc Mod due to
200ma per hour parasitic drain)
CQG S1 upgrade - (Gifted due to next mode memory)
DQG III AAA Ti NW - (With Green 6x2mm trit in tail and Magnetic clip)
DQG AA CW - (With Green 6x2mm trit in lanyard space and SS clip)
EagleTac D25c Clky Ti - (With 2 white 6x2mm trits in lanyard holes)
Jetbeam E3S - (With 2 6x2mm Green trits at switch)
Jetbeam RRT 01 - (With Green 12x2mm trit in tail, Glass covered, GITD around LED,
Magnetic side, brushed reflector and shortened clip)
Lumintop Worm Copper - (With 10x2.5mm Green trit in lanyard hole)
Maglite solitaire - (Changed incan bulb to 5mm LED)
Maratac cu 123 - (Awaiting Delivery Of… :slight_smile:
Nine LED TurboStar - (Added wings, In the Pond)
Nitecore EA4 CW - (With side clip, Green 6x2mm trit in tail, GITD around LED and Brighter
recessed switch mod)
Nitecore Sens AA - (GITD around window)
Nitecore Sens CR - (With Green 10x2.5mm trit in tail, Glass covered and GITD around window)
Nitecore EC25 Cobra - (With Magnetic Tail & Dimmed cyan switch Mod)
Nitecore Ex11.v2 - (With Green 6x2mm trit in lanyard hole)
Olight S10 Baton - (With Green 10x1mm trit in lanyard hole, GITD recessed switch mod and
GITD around new 20mm window)
Olight TC 10/15 Ti - (GITD around window)
Rofis JR10 - (With JR20 head so modes work with 18350 & 2 Green 6x2mm trits in
lanyard holes)
Rofis JR20 - (With 2 Green 6x2mm trits in lanyard holes)
Rofis JR20 - (With JR10 Head, single mode)
Ruinovo PowerBank - (2 LED Flashlight/ 5v Charger form FT with 2x Sanyo 2600 laptop pull
batteries inside)
Sipik SK68 - (GITD around LED)
Sipik SK98 - (GITD around LED)
SkyRay King Black NW - (With 12x2mm Green trit GITD waterproof switch, GITD around LED)
SkyRay G6 SS - (U3 LED, 2800ma 2mode driver with 20mm 15 degree TIR optic)
SolarForce Gladiator (18v XML T6 1 mode drop in)
SolarForce L2T (1 mode UV drop in)
Sunwayman C10R - (GITD around LED, GITD recessed switch mod and magnetic tail)
Sunwayman V10R Ti+ (With 2 Green 6x2mm trits in tail and GITD around window & LED)
Sunwayman Sirius Ti - (With Green 10x2.5mm trit in lanyard hole and GITD around window & LED)
Tank 007 703 - (GITD around window, steel clip and fixed spring)
Thrunite Ti - (Flattend Magnetic tail, GITD around window, steel clip and variable
brightness QTC Pill Mod)
Thrunite T10 - (Magnetic side & GITD around window)
Thrunite T20 - (GITD around window)
Trustfire S-A6 - (Fixed switch)
Trustfire F22 - (Destroyed driver so Direct Drive 1 mode for now)
Trustfire Mini 01 - (Flattend Magnetic tail so tailstands or sticks to metal surfaces, GITD around
LED)
Trustfire Mini 02 - (Magnetic side, GITD around LED)
Trustfire Mini 03 - (Magnetic sides, GITD around LED)
Trustfire Z8 - (Direct Drive 1 mode with XR-E Q5)
Ultrafire C3 SS - (Steel switch ground flat so tailstands)
Ultrafire UF-T1 - (Work in progress, blown driver/LED due to 10440 test!)
Xeno Cube E11 V7 NW (With 6x2mm Green trit at switch)
Next Light - Probably a Nitecore EC2 (ask FT about bulk buy :wink:
My EDC - TrustFire Mini 02 on keys, LM skeletool CX modded for legal UK carry,
Other light of choice, usually RRT-01, SWM V10R ti or Xeno Cube
As you can see, i went through a GITD/ Tritium phase. I have also found magnets to be very useful on lights although some don’t like it. I never use lanyards.
- Rechargeable Batteries - (Various amounts of)
AW - 16340’s
AW IMR - 16340’s
Eneloop AAA - 800’s
Eneloop AA - 2000’s
Eneloop XX - 2500’s
Energizer AAA - 1000’s
Energizer AA - 2450’s
Torchy IMR - 18350 900mAh
TrustFire - 14500’s Flames
TrustFire - 18650’s Flames 2400mAh
Nitecore - 14500’s
Nitecore - 16340’s
Panasonic - 18650’s 3100mAh
Panasonic - 18650’s 3400mAh
Sanyo - 2600’s (Laptop Pulls)
UltraFire - 10440’s Blue
Yezl - 10440’s
Yezl - 14500’s
Yezl - 16340’s
- Chargers -
Nitecore i4
Soshine SC-S7
XTAR WP1 (x2)
Anyway, there’s a mist coming over here so i’m away to play…
i would say welcome to the madness - but it seems as you have already been a part of it for some time :slight_smile:
Welcome… :wink:
welcome! quite the collection you have going. i have been using dropbox lately to host my pictures.
you like the trits huh? i think i may need to get some installed on my lights
Welcome!
Nice list of lights!
I use photobucket for image hosting…
It's nice to meet you, crx!
I have used Photobucket for years. But then, a few months ago, Photobucket went downhill fast. So I did a bunch of research on free image-hosting sites that allow hotlinking.
I decided to use Abload.de, and I love Abload! The website is in German, so it isn't for everyone. To translate the site, I use a combination of Google Chrome and Google Translate, and I think it's worth the effort.
This is the shootout that convinced me to use Abload:
http://www.tested.com/tech/photography/3563-the-best-place-to-store-your-jpegs-and-gifs-six-image-hosting-sites-compared/
In the comparison of six image-hosting sites, the clear winner is minus.com, but the article is from 2012 and minus.com is absolutely horrible right now. Abload fairs pretty well in the article and it's a good read, so check it out to see how much better Abload is compared to Photobucket.
Welcome aboard.
Judging by that collection you've either been lurking a long time or just have far too much time and money on your hands! This place will cure that.
Looks like you'll fit right in.
Howdy, crx!
That’s a impressive collection you have acquired. Congrats. Thank you for sharing your story too. It’s was a pleasure to read. Welcome to the forum.
Welcome to BLF. You have quite a collection going. Nice lights! :beer:
Welcome .
Welcome to BLF, CRX. You sure have a good list of FLs here!
I'm looking forward to reading your 1000th post ..
I'm in ..
Welcome to BLF.
For some reason that seems like the longest introduction ever for a “first post” that I have ever seen.
CRX, you do seem to ALREADY have an incredible amount of information about flashlights, according to your post.
We are not sure what you are looking for? What other needs do you have?
If specific, there are a lot of of members here to help.
Welcome to BLF! It seems you already love being here! ;)
Looking forward to seeing your photos. Hope you get them hosted based on the above mentioned tips.
You mentioned magnetic sides. A short "how to" would be a good contribution to the forum. Would you please? :)
And yes, I love trits too.
Welcome!
A great image hosting site is imgur. No account needed, 10mb max per photo but can upload unlimited photos and can be viewed unlimited times. It will never disappear.
As for your flashlights, where did you get your tritium from? Anyway I noticed that your brightest light is a SRK.
You need a monster to complete your collection.
