P60 driver/pill ring
I recently saw these… http://www.fasttech.com/p/1143102 the specs are off a little bit but they also vary from ring to ring. I took an average, the 5 I recieved were… Height: 3.25 Diameter: 17.98 Small outer ring (that fits into pill): 17.23 Inner ring (driver sits on) 17.25 The depth of the outer and inner rings is almost equal on each.
_
I figured that I would give them a try. Stacking them creates super pill.
Very easy to solder to. I joined one half of the ground ring. I don’t go all the way on the first date.
The two blobs at the top of the driver are the other securing connection. Just incase half isn’t enough.
Lots of room to stack chips or add copper. Or have empty air with stock wires.
Press fit (very snug, need pliars, for all of the pills I tried) and pry open. No more desoldering for me.
The solder on the pill in the picture above is because it is an old pill that I had used. You could seal it together with solder if you felt so inclined.
Thanks for looking
Bushwhacked
Looks like an option for those that can’t generate enough heat to solder to the stock pill.
Nice work bushwhacked
I have been using these adapters for awhile now in a different way. I use aluminium pills in my small lights which you cannot solder the drivers to. What I do is machine a step in the pill to suit a press fit of the adapter leaving a ridge for it to press up to in the pill. The driver is soldered into the brass adapter and then the assembly pressed into the pill. Touch wood its working fine so far. I have bought both of these adapters and unless FT stuffed up the ones I have received are all identical.
http://www.fasttech.com/products/1616/10001999/1250000
http://www.fasttech.com/products/1616/10001999/1143102-brass-17mm-to-16mm-rings-5-pack
So it looks like the 5 pack is discontinued, and a single quantity is $.83 if you order 5. That's pretty spendy for what you get. Anyone know of another place to get these? I'm looking to order a whole bunch.
What driver is that?
What do you use to machine that lip?
Very cool…thanks
Not sure Jonnyc. I ordered 15 the last time I got something from them. They work in c8 pills etc too. Sometimes have to dremel them down a bit.
Wish I had of ordered a lot more. I can confirm that the ‘copper’ 17 to 17 is the same as these.
Too expensive at .83 c a piece.
The sizes on these are confusing. There are several listed but it’s hard to tell exactly what they fit. Has anyone ordered all of them and have ID and OD measurements?
