I am wanting to add some power to my old xm-L manafont p60 dropin (the one that Foy loved back in the day). I opened it up and didnt find the 7135s I was expecting. Instead there were a couple of resistors with the number 2134. They look similar to the 7135s minus the middle leg on one side. Can i stack 7135s on top of these or it a different method with these drop-ins?
Also, is there anything else that I should be doing to increase lumens. I am wanting to do this one first before I switch over to my new XM-L2 from intl- outdoor(also a foy favorite….you can see i like the reviews before i buy), in case I screw it up too badly.
That is most likely a boost/buck driver in the pill. And those are not resistors if they have three legs, those are transistors or somethingh else maybe, dunno. You can not stack 7135 there! What is your power source? If you’re using single Li-Ion setup, the best way would be a new 3040mA Nanjg 105C driver. You’re not giving enough information and your not getting the answers you want.
Yes. I am using a single 18650 battery. I also happen to be waiting on some of the 105c with 7135x8 drivers and should have them in a few days. I was going to use them for other projects, but I can dedicate one for this. I have this dropin in a UF 504b host and while I know there will be worse heat issues than I already have, I am wanting to boost it up as high as I can for fun.
Thanks for the answers regarding the existing driver.
As far as I know the manafont drop-in is direct drive with possibly a resistor or two to stop it frying and PWM for dimming. It’s certainly not a linear regulator like 7135 based drivers.
The driver is actually the strong-point of the drop-in for output, as it tends to allow a high current. If you want more output the main things you could do are switch to a more efficient emitter, lower resistance cells to draw an even higher current, remove/replace any resistors (if there are any), or possibly even switch out the tailcap for one with lower resistance.
Have you been able to measure the current you are getting already with your current set-up?
Wrap the pill in the ali foil or a piece of beer can, add some arctic silver and it should do just fine. Im runnin one of those with XP-G2 at 2.57A in same host.
I don’t have any way to measure the current or output. It sounds like the improvements are going to come seperate from the driver, so that is good to know.
I will try improving my heat sink and add some thermal compound.
As for tail cap, I’m not sure i am ready for that. I really know nothing about it. I also might buy a low resistance battery. Any ideas on a good/ inexpensive one?
If it’s indeed a resistor based direct drive driver, all you need to do is to calculate the resistor value for desired current, since you know the input voltage and LED voltage drop.
