P60 Malkoff build - Driver Questions
Hey all!
I have an odd build I’m working on but looking for some options / suggestions.
I have what I believe to be an empty Malkoff p60 drop in pill. Plan is to use a 20mm MCPCB with a single L351D emitter. Worked out that a convoy 23.5 TIR fits perfectly in this setup with the board height and optic height to align with the top ring of the pill! Issue I’m struggling with is available drivers that fit.
Measuring with calipers the rear shelf for a driver is only 16.1mm diameter so a standard 17 won’t fit. Have been searching for options that won’t overdrive a 351 and struggling to find something that would work. I believe 3-5A would be ideal with 5 pushing the upper threshold
Options I’ve looked into for 15mm boards:
-Mountain Electronics MTN-15DDm FET + 7135 - concerned with overdriving the LED
-Kaidomain KZ-3006 1.5A - probably a decent option but lower end of power range and limited modes.
-Kaidomain 350mA Boost Driver - possibly but would rather something higher quality and alternate mode availability
-CWF Dragon Mini FET Driver - out of stock and concern with overdriving. Reached out and more are going to be made but unknown timeframe.
-Okluma Buck- probably absolutely prefect but after reaching out they don’t sell bare drivers
-Copper and current 15vp v6 - decent option but out of stock
-Edoluc Light Glow Arrow driver - 14.5mm so may work, possibly buck driven, no bare board so would have to buy their pill kit
Other options:
-Attempting to bore the diameter of the shelf to around 16.8mm-ish and file a standard 17mm driver down a little. Doable but I doubt I can make it look clean with a dremel :laughing:
-Run the mtn board with a lower amp battery
I’m probably missing something there so hopefully someone here has some suggestions or willing to part with a board that may work?
Thanks!
Seems like you could sand 1mm off the edge of a 17mm driver, that’s not much all the way around.
I concur
I figured that would be the solution, plus open up a lot more options for 17mm drivers
Convoy 3v5a group 8 would work well I think.
Time to brush up my dremel/sanding skills
Worried about taking too much off the driver and losing the ground ring
Naw, forget power tools, because it’s too easy to linger a bit too long and grind off too much.
A fine file works best, give it a stroke and sweep like you’re combing it’s hair or something., then twirl it a bit and keep going.
Every time you work your way around, you’ve taken off an even amount all around.
Or alternatively, sandpaper on a table and stroke and twist the driver the same way.
Agreed! I’ve used sandpaper a few time before with success but I have a feeling I’ll have to bore the pill a little as well so dremel for the pill and hand sanding for the driver
Do you have a power drill chuck big enough for the pill, or a lathe where you can put the pill so it can spin relatively concentric as you sand it?
At work, yes! Was I smart enough to bring it in to do that? No! :laughing:
If I had patience I could wait till Monday but I lack in that area sometimes. I may have to get creative and have it held down with some scientific pressure sensitive tape on the front of a drill.
I apologize for this not being “driver-related”, but I’m very curious where you got that empty brass pill?
Does the interior look like it used to be filled with anything (potting material), or does it appear to be a virgin shell.
While its geometry certainly looks like a Malkoff P60, other similarly-looking P60 shells (manufactured in small batches), have been available over the years for purchase on BLF, CPF, Mountain Electronics, and elsewhere.
More relevantly, I’ve never read of anyone (modders) successfully removing the notoriously difficult to remove potting material that Gene Malkoff uses, not to say it hasn’t been done successfully. Since Malkoff has never knowingly made his P60 shells available for purchase, I’m very curious if the shell you have is/was a new or modified Malkoff P60, or another. Perhaps photos of the interior would be possible!
As one who appreciates the P60 format, I would appreciate knowing what methods and materials were used to cleanly remove the potting material and if the electronics can be salvaged in the process. Thank you.
Hey! No worries at all. I got this pill from a fellow enthusiast, bought some leftover old empties quad pills they had. Still searching for more as a side not they’re getting harder to come by.
When I got it there was a single emitter and MCPCB already in it but no driver and none of the potting was there. Wish I took pictures prior to removal but of course I didn’t.
It may be a custom pill but I swear it looks exactly like a Malkoff. There’s no engraving on it either, which I know is usually an indicator of Genes work on the pills.
I’ll get you some pictures later this evening with a comparison side by side to one of my other malkoffs prior to any modifications I make
Forgot to mention it looks like it never had any potting in it, so maybe somehow they got ahold of an empty from him?
I would also be interested in some brass blanks, lol…I want to make a wide input range/battery vampire…Vampire for the primary 1.5V and less, accepts cells in configs up to 15V (4×3.7V), jury rigged car battery, that kind of thing…If necessary, just thread it onto an adapter and drop it across the live battery terminals for regulated 10-100 lumens of light no matter the source
Thank you for your reply. If you do take any more photos, please include the tail end. If it has the same black potting material and fairly unique spring that Gene uses, that will help identify it. OTOH, if it lacks the Malkoff engraving or laser-etching that has always been a hallmark of Genes quality, well then…
If the person you bought it from could tell you if it’s a genuine Malkoff drop-in or not, and if so, what was used to completely remove the potting, that would be great. As much as I would like to attempt modding one of older M61s, I won’t sacrifice one without knowing how that black potting is removed without spending hours trying to get it out cleanly.
Thanks again!
So I took some side by sides, I have a feeling this may be a clone. There’s some slight variations on thickness of the front bezel side and rear where the driver would go.
I’ll try and reach out to the person I got it from to see if he had any idea where it originated from. Definitely seemed like there wasn’t any of the typical black potting in it and like I mentioned the rear side was bare when I got it, no driver installed. Ignore the v grooves on the back end I added those a few weeks ago to make it easier to pull a driver if it fails, originally they weren’t there.
Onto the main show! :laughing:
Used a dremel to carefully bore out the tail end. Managed to not destroy the driver shelf either so I’d say it’s a win. Also sanded down the convoy 3v5a driver a bit and it fits!
Onto the other side. I originally was going to use a 20mm mcpcb which does fit perfectly in the bottom of this pill but swapped out to a 16mm one. Reason for this this? I had an old 20mm glow ring that I thought may fit and help center the MCPCB in the pill. Ended up working great.
Used a 15 degree 23.5mm TIR from Simon’s shop and lightly press fit it in. I didn’t want to use a TIR with the plastic centering ring holder thing since I planned to have the glow ring in there, figured it would take away from the cool glowy effects. But still looks pretty good!
Put it in a Solarforce P1d that I got from a very generous member here and on CPF :blush: glow ring adds a neat multicolor afterglow effect too!
My only mistake: swore I never touched the TIR backside with my finger but apparently I did so there’s a nice fingerprint mark on it :upside_down_face:. When I get more time I’ll somehow get the TIR out (destructively if I have to lol) and replace it. Lesson learned? Wear nitrile gloves when handling optics.
Ran out of time and couldn’t get any decent beam shots worth while, work is only a few hours away now. I’ll try to get some tomorrow evening.
Now I need another one of these clone pills wherever it came from. But overall definitely a fun build.
This looks great well done. My only suggestion would be to use a linear driver instead of buck as the Vf of the Samsung lh351d is very high. FET also works well as it won’t draw that much current due to the high Vf.
I figured linear would be better for it and was looking into options when I originally was searching for a 15mm driver. Once I started getting into the woods with opening up the pill I didn’t feel like waiting for something to come in :laughing: and had a few of the convoy buck drivers on hand. Figured it would work relatively well. Keeping it in group 8 helps with my amperage concerns and some better run times, not sure what the dropout is for the convoy driver.
I hear that, its easy to let perfect be the enemy of progress! If it works it works
A maker’s mark, proof/evidence of your involvement…it’d be cool if you eventually used a partial as a trademark, complete with a nano etching saying “Pizzanaut” or similar in the lines of the whorl…
We did just get a pretty nifty dual laser engraver at work, I really should start bringing crap in on the weekends to mess around on.
