P60 Malkoff build - Driver Questions
@KnotSoMuch I did get in touch with who originally had the pill and surprisingly it’s a legit Malkoff P60!
He mentioned it came from an old ZFL Elzetta so wondering if that’s why it has no engraving on the body and the slight body differences since the ZFL pills I believe originally came with TIR lense.
Also mentioned it took a lot of work to get the potting out. He used a utility blade on the side walls and flat head heat station to get it out from what he told me, so I guess it’s possible with enough determination.
Thanks so much for taking the time & energy for confirming and sharing that information.
Thanks as well for documenting your repurposing of that former Elzetta drop-in!
Anytime, glad I could give some info on it!
Managed to get ahold of a reasonably priced m60 and figured I’d give modifying the pill a shot. I feel a little bad for destroying a perfectly good Malkoff drop in but the results of the last one was better than I expected so off I went.
So to start off, there is no way to save components from this tear down. Everything is epoxied/ potted in place other than the TIR. These things are built to take a beating!
Originally tried to let some acetone sit on the potting for a half hour hoping it would make it softer but didn’t seem to make any difference.
Used a xacto knife/multitool to scrape off a bit but eventually got my rotary tool and ball burr tip out then went to town.
The driver doesn’t fill the full rear end of the pill, both sides had an opening on them. Plunged the ball burr down there to try and remove as much potting as possible. Eventually removed enough to pull the driver out with pliers
Got the rest of the potting out with pliers and brute force.
Some of the components ended up staying in the potting.
Optic side - popped the TIR out and started to cut the plastic holder out with the xacto knife.
Did the same thing as the rear, burr ball to remove as much potting/epoxy as possible
Tried multiple times to pull the MCPCB out but it wouldn’t budge. Eventually put heat to it and it fell right out.
Used various size sanding stones/disks to remove any leftover potting from both sides and did the same modifications as last time (v notches to remove the driver, open up the wire pass through holes, widen the pill driver end and sand the driver down a little) except this time I added two additional small holes near the top rim if I ever have to get the new TIR out, should be able to pop it out with a small drill bit now.
Had a second confetti glow ring, test fit that and the new MCPCB, fits pretty well
Ran out of time today to finish it. Hopefully later this week or weekend I’ll complete it.
I was gonna suggest heat from the start. Throw that sucker in the oven ( make sure the wife isn’t home ) JK
I meant to mention that solder flux and high heat seems to work well at cleaning out potting, though I’m not sure if it’s just the heat…
Woulda tried that on this one! Honestly wasn’t too bad with the burr ball but I’ll have to keep it in mind if I try this again, would have spent less time scraping away the potting
The burning MCPCB already had a wonderful smell I’m sure the rest of the potting would add a nice undertone to it :laughing:
Years ago I bead blasted some stainless bezel rings. I used some bake on black lacquer paint and baked them in the oven. The house had a smell afterwards and our food seemed like it smelled that way also. Had to run the Clean mode to clear it up :rofl:
Was able to finish the pill tonight.
Last second swapped to a B35AM 4500k setup, wanted to see what the beam would like. A little funky but fine with me, I enjoy trying goofy and different setups. Wore gloves this time when putting the TIR in, learned my lesson from last time :upside_down_face:
