P60 reflector kit for XP-G2
Can anyone recommend a suitable reflector kit (with springs) for an XP-G2? I’ve found heaps recommended for XM-L2 and XR-E but nothing for XP-G. I’ve searched and the only previous thread lists whole modules, or a bare reflector from solarforce. I guess I could go this route but then where do I find springs.
Will any of the fasttech XR-E or XM-Ls work well? Thinking of using an AR lens with it too.
Here this should work for the Xm-l or Xpg, first check with fasttech
I’ve had good results with these for xpg2:
http://www.fasttech.com/products/1605/10002800/1208509-empty-aluminum-orange-peel-drop-in-module-for
http://www.fasttech.com/products/1605/10002800/1208506-empty-aluminum-smooth-drop-in-module-for-cree-xp-e
XR-E reflector will not work with XP-G but is good for XM-L
I think it’s fair to say that this product will interest you:
XM-L Reflector to XP-G Reflector Converter Adapters (2-Pack) fits for 7mm bottom opening XM-L reflectors (FastTech)
I have only used one of them, and briefly, but I was happy with the results. I think others here have used them more extensively and can chime in with better experience.
Those look very interesting, might get them just to be safe.
hmm, direct contradiction… However as rojos seems to be talking form experience I reckon I’ll give the smooth a go, then if it’s no good fit the adaptor!
Hmm? XR-E.
ok my bad~~ too many similar acronyms!
Just to clear up any confusion, the drop-ins that I linked to have reflectors that are sized for 3535 XP footprint emitters. The emitter openings are the perfect size for XP-E, XP-G, XP-E2, XP-G2, Nichia 219A, 219B, Samsung 3535, and any other 3.5mm base emitter. You won’t need an adapter.
Go with Rojo suggestion you will not need a adapter
ok well that’s cool - because I ordered the smooth one you linked to!
Looks like I'm to late but heres another.
http://www.cnqualitygoods.com/goods.php?id=1415
