For years I’ve wanted a light mounted on my pump shotgun. I’m finally getting around to it. I decided to go the P60 route. I ordered a Solarforce L2P with the S10 switch (exposed forward clicky).
I like the floody beam pattern of my Convoy S2+ and would prefer something close to that with this P60. I’m thinking of using an XM-L or XM-L2 with an OP reflector. 1400mA in my Convoy seems like a good balance of brightness vs. runtime, as well as heat management. I live in the desert, and this time of year our lows are 80-something degrees. I suspect much more current would cause a P60, with its poorer heat conductivity and not being held in a hand, to become too hot if run for very long this time of year.
This light will need to stand up to stout recoil (12 gauge 3” magnum loads), so I want to pot the driver. After some reading, I’m leaning toward using Devcon 2 Ton epoxy mixed with either aluminum oxide or silicon carbide.
The driver must be single mode. The single mode drivers I’ve seen don’t have any low voltage stepdown or shutoff. I’d really prefer a shutoff. I worry about the switch being activated when transported in a gun case. I plan to use a protected battery, but still…. I noticed that the guppydrv firmware offers a 100% only mode and can be mode locked by soldering a star. I presume this isn’t a one-time thing, as in unsoldering the star will allow setting a different mode. Is this correct? Guppydrv will at least reduce output below a certain battery voltage. I could set to 100% and lock, then be able to change later if I use the drop-in for other purposes. I’m thinking of extending the star contact and a ground up through any potting material. Maybe I should just stick with a single mode driver and forget about low voltage? I’m new to Li-ion, and cautious.
So, right now I’m thinking of ordering the following from Mountain Electronics:
P60 with OP reflector
QLITE REV.A 7135*8 3.04A LED DRIVER - 17mm — flashed with guppydrv (I’ll remove some 7135 chips to reduce the current)
XM-L2 on a 16mm Noctigon
protected battery, probably an 18650GA
I plan to add some mass in the pill, such as sanded pre-1982 pennies if I can’t scrounge up anything else. And, use foil or make a copper insert for good pill contact with the light.
One big remaining question is what about battery springs and/or buffering material in a light that will experience heavy recoil? Are certain springs better? Should I add some sort of shock absorbing material under the head toward the limit of spring compression? I think with the P60 potted the driver should hold up ok, but I worry about the top of the battery getting pounded. Should I, or can I even, not use a spring on top at all, and go with a brass or copper button instead?
Any comments or suggestions? Making something like this is rather complicated for a first build.
