all right, this doesn't make sense to me, maybe someone can explain it. following are tailcap readings from six P60 drop-ins, and two other well known xm-l lights. i know the DMM is not anywhere near great, but it has been consistent and fairly accurate, at least with regard to cell voltage charge testing. these readings are averages based on multiple tests with different batteries and have been consistent, so if not totally accurate the readings are at least relative to each other.
first two are custom mods, one-mode, solder filled, and without a doubt the two brightest i have or have seen, 900 lumens +/-
1) 1.9 2) 2.0
next two are well known, one custom from erik and one mf uf, both three-mode. these are both very bright, great drop-ins, very close in brightness
1) 4.1 2) 4.0
next is KD warm white five-mode, 3.7, and either KD or DD five-mode (not sure which one i tested, one is mounted on my bike and i didn't take it off, but they are virtually identical in tint and brightness to the naked eye) 3.8
for comparison purposes, xeno v2 ww, 4.1, and drop-in (actually screw-in) pill from KD c-8 that i put in a smaller MTE host from dx which previously had a ssc P-7, then a MC-E, has been run over by a car, and now has an xm-l. it is five-mode, 3.4.
i'm assuming the one-mode set-up has something to do with the readings, but otherwise i am at a loss. shouldn't the higher readings equal brighter lights? maybe this makes sense to someone, or at least maybe the info will be of some use.
