Panasonic CGR18650CH high C-rate battery uses Nickel and Manganese as negative material, improves battery energy density and work voltage, good high C-rate discharge performance, appropriate to assemble application,
Product features as below:
Min Capacity:.2000 mAh
Typical Capacity:.2250 mAh
a. High cell energy density and voltage;
b. Good high C-rate discharge performance, highest discharge current up to 10A (25℃);
c. Appropriate to medical device, flash storage, back up power, portable power tool etc. high current discharge device.
Storage of Panasonic 18650 power battery:
Battery storage environment temperature –10℃~ 35℃, if battery stores 3 months above, storage environmental temperature should be temperature 23 ± 5℃ and humidity 65±20%RH. Long term storage voltage should be 3.6V to 3.9V.
