Panasonic NCR18650BE "E" for economy?
top and bottom look different. can’t find any datasheets…
i wonder if they are in the same family as the imr hybrid ncr-bd that i just ordered 4 from fastech
Found this , don't know where he got it.
https://www.fasttech.com/forums/1686800/t/1234836/3-6a?1235610
couldn’t find info so i did my own testing
about 4% less capacity than NCR18650B but around 20% cheaper. a win in my book…
Now we just need a groupbuy :slight_smile:
We need voltage sag (high drain) test :frowning:
Not for power banks and low currents :slight_smile:
I received a couple of batteries from Keeppower this week, one of them is a 3200mAh 18650 with 20A rating.
Оо cant wait!!
If the sag is low, it will be great :slight_smile:
Edit, are this the ones? if yes that is a no go for me :frowning:
http://lygte-info.dk/review/batteries2012/Common18650comparator.php
Ah yes… :slight_smile:
No, that is 4.35 volt batteries and they do not support 20A, the new ones are 4.20 volt batteries.
I picked non 4.3/4.35v cell, it says Keepower 3200 mah black (2014) but thanks anyway, you sure know alot better then me lol.
Yes, a 4.35 volt cell will have 3 entries in the comparator, one for each charge voltage I test it at. The 4.20 volt is not specified, because it is the common charge voltage. Testing 4.35 volt batteries is very slow (3 weeks), due to the 3 voltages.
Ah ok, i didn’t know that, thanks :slight_smile:
I have some BE’s inbound, and I was told they are 10A rated despite what some other sites like fasttech say.
It does make sense look at the model number history for Panasonic:
B, A, G = normal laptop cell
CH, PD, PF = 10A cell
So based on the supplier information, internal resistance testing the supplier provided, the BE’s are 10A+ rated.
So anyone has some tests on this? @4A +
protected versions just popped up on FT. I’m trying to find a good protected cell with low internal resistance. Illumn.com has them listed as “High Discharge” but has anyone done more tests?
