Panasonic phone battery oddness
We have 2 line Panasonic dact 6 cordless phones, half a dozen handsets around the house and like them a lot, but they seem to really run the NiMh batteries hard. These phones are not cheap, so in my ebay effort to save few bucks I pieced the batch we have together from several lots of misc parts. End result I have two less charging bases than I do phones, and need to rotate them every few days to keep all of them charged.
Odd part, takes 24 hrs in the base to fully charge the two AAA NiMh Panasonic batteries in each handset, so I put 4 of them in my LaCrosse BC700 to charge and refresh while the other handset and two batteries went in the base. BC700 took all 4 over 1.4v, but as I recall shy of 1.5v, and all of them showed as one or two bars short of a full charge when placed in the handset. After a few hours in the base all showed fully charged.
We have had them about a year, and they are all going strong, but makes me wonder how Panasonic gets away with running the batteries so hard. Batteries are Panasonic branded, and not cheap to replace, so I also wonder if the batteries are special.
Those look to be ‘stock’ NiMh. Put whatever you want in there. You don’t have to use their batteries. Decent AAA will get you better results than crap ones though.
The base unit uses a very low charge rate. That’s why you can leave them in there ‘forever’ without destroying them.
A full NiMh is just over 1.4v. It WILL NOT hold that level of charge long. An NiMh over 1.5v is overcharged, probably hot, and starting to die. I wouldn’t put a lot of stock in the phone’s metering. Checking NiMh capacity with only voltage is mostly wishful thinking.
Hard running? Not a lot of capacity in AAA. If the phone is ‘doing a lot’, then it’s going to use it up. My cordless phones last a bit less than a week on standby. Using them taps into the life considerably more.
i use those at the shop.
i would say the charger is “semi smart”
the designers didnt take into consideration that someone might want to extend runtime by swapping the batteries rather than “charge for 7 hours” it wants you too.
i have done this and while it shows lower charge state it figures it out in time.
We get around 5 days with the phone showing all bars on the battery off the charger base, which seems odd to me as the BC700 won’t charge more than what shows as one bar down on the handset. That makes me think the normal operating range on the battery is just the part above what the BC700 thinks is max charge.
I think one I bought without batteries and put Eneloops in, so far no issues on any.
We really like the phones, don’t make a lot of calls with them, we have a VOIP and 4 cells, but we do use the intercom function a few times a day.
