Please report here what your meter will show, thanks Pulsar.
I don’t have a light meter or any other GTs to compare to, but what would this one be classed as…
…not real good… Looks like mine.
Notice how the base circle is mirror finish, but the walls are OP.
To be fair, I’m not asking for a perfect, mirror-finish reflector, but on the other hand, I won’t be buying a mirror with a finish like that either, would you?
Rest assured, these concerns of mine are never directed to the GigglesTeam, which has done a great project and bring it to reality.
Objectively, my concern is only about the finish of the reflector, of which obviously is Lumintop’s prerogative.
Is it a different centering ring that others? I see a black squared ring around the LED,of course pictures might fool me
Well said Nev!!!
Sure, there will be some “bad” reflectors… I do not doubt that a bit.
BUT PERSONALLY…….What ticks me off ROYALLY is this:
After beginning production with the V.2 reflector…… Lumintop, bowing to the pressure of a minotity of people complaining about “slow shipping, I don’t have my light, yada, yada, yada”; changed back to the V.1 reflector in hopes of faster shipping to satisify the minority of complainers.
Then of course supposedly they have now changed back to V.2…… but who knows when that happened.
To me it is inexcusable that a minority of complaining people in this Group Buy caused many others to NOT GET the V.2 reflector that was actually a bonus …. because V.1 was all Lumintop was required to provide.
And no… this will not be sorted out & fixed. It is what it is!
The above is NOT speculation.
It is my personal opinion based on the information TA has provided in this thread.
Definately looks different.
The centering ring was changed, due to small shavings coming off when the assembly was tightened, & possibly burning up on the LED. Looks like LSX got one of the earlier one’s.
Is MY reflector V1 standard?
I don’t remember the prototypes being this orange peel.
GT on top, FET C8 below, both in the highest mode, from 8 meters. Note the off-round spot.
I added that myself as my LED wasn’t centered, it’s an XP-XM adapter that I trimmed the corners off.
Bruno28, I think 200kcd could be caused by the height of the led relative to the reflector. Have you tried adjusting it by tightening or loosening the head a bit?
Yes, it looks like a bad centering and height adjustment. I had a similar issue with my Palight Boss, and the white wall shot looked very similar to the first reflector when it was out of focus. Since it has a rather big reflector as well, it seems to me your problem could have the same root. Emitter position and centering are crucial in these large reflectors. Try focusing it and post your results then, I am curious to see it.
BTW, do these centering gaskets fit? https://intl-outdoor.com/cree-xpgxpexte-led-reflector-positioning-gasket-10-pcs-p-601.html They are for xp-g emitters with the chip size 3.45mm, which is the same as xhp 35 emitters. They are made for reflectors with base aperture 5mm.
Wennn your reflector looks horrendous. Sorry you got one like that.
agreed…
A few post back some one showed a light with a handle on it that I thought looked cool I found the site the picture came from and checked it out and they have a light that looks simular to what u guys have any way here’s the link http://www.lemax.cz/searchlights/25-lemax-lx70-superpower and still waiting on email :frowning: list number 1288 ).
Wennn sorry but in my opinion your light looks way worse than the V1 proto !
I would be very displeased if my light turns out to be like that when I receive it :confused:
I really hope there will be a way to buy a V2 reflector in the future for all the people who received their lights with an inferior one and would like to change it.
So with all the bad reflectors, what does the team know about getting the correct ones. Since it’s not a isolated case. So to be clear from someone on the can you tell us what is going to done about it. Has someone from the team talked to lumintop about this what have they said. What has lumintop said about getting the reflectors. If the team hasn’t talked to lumintop about getting the correct reflectors they need to start, and find out what they are going to do to put this issue to rest.
In case you decide to play around by tightening and loosening the head it would be great if you could try the reflectors all on the same host. Maybe a few things add up to the bad result. For example the LED of light 1 could be underperforming cause it’s on the lower end of the flux for the binning or has a really high forward voltage.
Oh boy…
Just catching up here, it seems the road (and the reflector) got a little bumpy huh?
FWIW, i’d rather wait an extra month to get a nice reflector.
So i’m fine with April or May. LOL :person_facepalming:
Hope my order won’t delay the Facebook sales….
What an adventure…
1 of 2 blf gt has arrived! in NZ!
This thing is a beast!
Many thanks to the team, Neal and Lumintop for this!
Special thanks to TA for stepping up in Millers absence and keeping cool under all this.
