reserved for Quotes of user tests and information about the GT.
Emitter tests from Maukka:
At maximum ramp level (2 amp) measured 4100K at a perfect tint of duv -0.0009.
(click for full size)
Runtimes with 4 cells only:
MRsDNF:
Talking about things happening here is a run time chart with the BLF GT proto Narsil running Two Amps at the end of ramping.
The runs were stopped when the low voltage kicked in for the first time.
(This is a battery comparison at 2A. Note that the 3500mah cells have extended run times after it falls out of regulation, blue line.)
MRsDNF:
This chart is a comparison running the BLF GT on high, the original Narsil at 2.5 amps and the proto Narsil at 2 amps. Both runs were with 30Q batteries. (This test is only about comparing 2A runtimes to 2.5A. The 2A red line stays in regulation much longer.)
Texas_Ace:
Also remember that those runtime tests are with the short tube 4 cell version, 45 mins from 4 cells before even dropping out of regulation! That is properly good.
So expect about double that from a long tube with a full 8 cells.
About 1.5 hours of full powered runtime and another ~1.5 hours before it hits LVP.
Thermal pics from Lawallac
Within a few seconds of turn on.
After running about 2 or 3 minutes.
