pbcheap.com – Everything LED Lighting
Everything made with LEDs. Find everything from loose leds and led drivers to finished LED fixtures, LED Light Bulbs, LED Landscape Lighting, RGB Color Changing LED Lights, etc.
www.pbcheap.com – Everything LED Lighting
Links to technical data, text and schematics for the beginner and the experienced LED user. These links will help you determine what to purchase, how to work with the LED products, where are some of the resources, and to provide as much in depth technical knowledge as we can to those who require more than a passing knowledge of LEDs
Luxeon LEDs, Assemblies, and AccessoriesSide Emitters
The Side Emitting LEDs directs the light beam 90 degrees off the optical axis in a 360 degree rotationally symmetrical pattern. This produces a toroid of light that is useful for lighting large opaque surface areas. Side Emitters are as is, no Batwing or Lambertian designation.
Luxeon EmittersLuxeon EMITTER is the basic building block of all Luxeon Power Light Sources. Luxeon EMITTERS give you total design freedom by allowing you to design from the ground up enabling a fully integrated lighting solution design…
http://www.pbcheap.com/led-light-flashlights
Hi and welcome nomanni.
You may wish to read the info on this link.
http://budgetlightforum.com/forum/misc/commercial
Yeah, move it to the Commercial forum — don’t worry, everyone will still see it, it’s just a way to make clear that it’s a topic started by a business
But note— you really need to proofread your text, get a native English speaker to go over it for you.
For example, this item:
See the problem?
