PFlexPro TAC
I thought some of you might find this interesting. I have been using bored surefires and elzettas for a while. I wanted to upgrade my malkoff modules with something with more output. I kind of stumbled on pflexpro and it had all the features I wanted:
single 18650
p60 drop in
1000+ lumens
multi modes
I ordered a module and it was nice. I emailed Randy at Pflexpro about submitting a light for me to review. I write reviews for the austin police marksmanship team blog. I kept coming up different things I wanted the light to be able to do and Randy was able to accomadate this.
The basic specs are:
xml2 led
1200 lumens
choice of smooth or op refelctor
fully potted
22 modes with the ability to lock out the menu with contacts on the module
I did a torture test and the light held up very well. I ended up destroying the bezel, tail cap, and a battery but the module still worked. Video below.
I also wrote a very long review that is on our team website.
awesome
I have no Idea what some here have on these dropin lights
The poorest heat transfer combined with 10-12W High Power LED or more…
On the one hand, people solder their MCPCBs to the pill, on the other hand, DropIns are good - how does that make sense?
I watched the video after Randy posted about it here.
Crazy tests, my lights would never get beat up that much. I was a little suprised at how much damage the solarforce took, but even more surprised that the module survived the dunk test outside the light.
P60’s are not great thermally, but if they are wrapped tight and not driven too hard, it will be just fine. 12watts in a P60 is no problem.
Wrapped?
With aluminum foil, like I did it with my only dropin - W501B with P7?
That is sub-optimal, and I think that not many make that (it takes the “fast change” a bit away, doesn’t it?)?
But yeah, it will work. Those china-lights with a hollow pill work too :stuck_out_tongue:
If a 32 watt XHP50 can survive in a P60 with some tin foil, I think a 10 watt XP-L will do just fine :wink:
Definitely not optimal, but they’re a great starting point for getting into the flashlight hobby. Even 2 amps will ‘wow’ a muggle.
They are wrapped in copper strips. There are a bunch of pictures in the written review.
You select the menu you want through tailcap presses. If you no longer want to be able to change it you use the contacts on the module. Essentially it prevents you from ever accidentally entering the menu although it is pretty hard to do accidentally
Just got done reading your review. A P60 isn’t hard to make, but he obviously spends a great deal of time on small details that many people would ignore. Props to Randy on his process.
I am sure most of you have a much better understanding of the technical details. I know the light works well and it is tough. I am using the module and body from the video at work, it has a new tailcap and bezel.
That’s all that matters!
If you stick around on this forum you can learn a lot in a short time.
Here are a couple more pics.
This is the damaged bezel from the video. The impacts bent it into an oval and broke the lens.
The damaged battery. The positive nipple was bent back into the battery.
One neat thing about Pflexpro is that they test every light or module. They ship with instructions and output ratings for that specific light. These are the ratings for the light from the video.
I’m glad the Solarforce held up as well as it did…I’m even more glad my drop in survived.
After looking at the host damage, I wonder how much less damage would have occurred to the head if the L2P had the stainless steel bezel (about $6).
I know, it depends a lot on the type stainless or type aluminum used, but I think the stainless bezel would have offered better protection to the head and glass.
Another advantage to the stainless bezel -if it gets nicked from a drop, it’s not as obvious.
That’s some very well thougt-out P60 drop-in. Thanks for the review. I wonder how much it goes for?
