Hi, It is most a pic review of this batteries, I dont have a vernier to make the exact measurents but here I go, I just can make some comparing and test fit with my lights. Received in 14 days from china to venezuela.
Order from here
Using the code coupon BLF you get 5% discount
Well protected
Bill and box to protect the batts.
Comparing pics, is kind big, dont fit in my SD6, H600w, but fit in my ultrafire C1 and 501
Perfect fit in the i4 charger
Measurements of the 3400 batteries and some pictures comparing with others
3400 top button from Fasttech
3100 top button from another dealer
3400 Intl-outdoor flat top
I think that whoever installs the PCB should remove the original packaging of the battery to make them a little thin, but this way is left to show the originality of the battery
I will make some current test in a couples of days
They FIT in the following lights:
Armytek Predator
Jetbeam M1X
Spark ST6-460NW - The cell slides in and out easily, but not by gravity alone. The length is fine.
Ultrafire C1 and 501
SolarForce L2N host
SolarForce L2P (at least in mine)
SolarForce L2P (older, about 2 years prob)
SolarForce m8
SolarForce L2
Old style L2 with extender and MPP-1 head, though it didn’t drop in full speed due to air cushion so it’s a tight fit.
Sky Ray King
TN31 (very tight fit tho)
Fenix TK75
Sunwayman C20C “Tomahawk”
Shiningbeam Blaze
Nitecore P25
Paladin i6
Keygos KE-5
SkyRay King
Sipik SK98 flashlight
Jetbeam M2S
Jetbeam BC25
Crelant 7G6CS
Crelant 7G5CS
Crelant 7G3CS
Crelant 7G2CS
Armytek Barracuda
BlackShadow Terminator
Aurabuy C8 T6
Tight Fit for
Eye 15
Fenix TK35
EagleTac G25C2 Mark II
They FIT in the following chargers:
- Nitecore Intellicharger I2
- Nitecore Intellicharger I4 V2
- Miller ML102
- Soshine SC-S7
- TrustFire TR-003P4
- UltraFire WF-188
- Xtar SP2
- Xtar VP1
- Fenix ARE-C1
They DO NOT FIT in the lights below:
ZebraLight sc600 (too fat)
TM15 (too tall, but does work if you tighten the head like hell, not rec’d)
ElektroLumens SAR (too fat!)
FireFoxes3 (too tall AND too fat!)
Zebralight H60
SD6
H600w
ST360-CW
Cannot Fit / Too tight (fat) (but can force in and have hard time to take it out) for
Fenix E50 (Single / Double Cell). Double cell will crash the -ve end of the battery
KD C8
They DO NOT FIT in the chargers
- UltraFire WF-139
in the “USB power bank” (2*18650) that I got from eBay.(It’s the white one with a slide-in design and an orange “ULTRACELL Plus+ Smart Portable Charger” sticker, although it is sold with other names/stickers as well.)
As for Fenix PD32UE, as mentioned by other forumer, it is cause by the -ve plate is a bit raised as per pic below (right). To make it work (initially), I put a round donut ring tape (got it from notebook battery pack) at the bottom of the battery as per pic below (left). Then it will work.
But, due to limited quantity of the donut ring tape, I put it at the tail cap - spring area as pic (right). Left is the original without donut ring tape.
By doing so, I can use all 6 batteries in PD32UE.
I will update all this info if someone can share with us…
