PilotPTK 3 XM-L Module-Build Log
It will be a solid mass when you are done. You could drill through that and run the wires through the holes.
I would layer some 3M copper tape around your heatsink and press it into the mag tube. You should be able to achive a nice snug fit with no air gaps.
Regarding your tailcap, and removing anodize to make electrical contact. Drain-o and Lye based drain un-cloggers will dissolve Mag-anodize. Just fill the cap with drain-o for ~15 minutes and let the stuff dissolve.
Good luck with the build!!
Ok, thanks for all the help everyone. I followed kramers advice and heated it up on the stove and did that. So now what should I use to fill the space between the heatsink and the tube? Would something like this work?
I already removed the anodization in the tailcap and now have the battery making direct contact with the tailcap. (I added a solder ball to it)
I did a pair of alu mag heatsinks:
Nice. Are those for sale. :)
Nope.
The first one is instaled in a 2C mag with a XR-E R2.
The second one is heavier, for a XM-L U2 direct drived.
I've also removed the anodizing in the inside walls of the maglite (with caustic sosa) that contact the heatsink.
I've also machined a 2xC to 1x18650 adaptor in nylon with a 5mm solid coper wire for positive contact:
Darn, I was hopeful. I guess I will continue using my heatsink. :P
It was just to give you an idea
Oh ok. Sadly I don't have a lathe. I may just break down and order a heatsink.
scaru, did you never play with tin soldiers? My dad bought an old set on a peddlers market, containing kilos of tin bars and forms to make our own soldiers. Thats what I use to fill large gaps, hollow pills and so on. Way cheaper than solder but pretty much the same.
There are a lot of people out there selling aluminium heatsinks for Mags.. some large threads over at CPF, but imo its a huge difference if you make something on your own or buy it somewhere.
Btw, I really had to laugh at the conversation with UPz! "I built some.." - "You sell those?" - "Nope. :P " :D
Sorry, my english is bad :P
Nope, haven't ever done that. So any one have any recommendations for how to fill the gap between the heatsink and the body?
3M copper tape will do the trick. Try to don't leave air bubbles.
Any recommendations for a cheap source? As in not this. http://www.amazon.com/3M-Shielding-Tape-1245-Copper/dp/B0000WRJK2
Good...
BETTER..
(google search: 3M copper tape)
http://www.epd.com.tr/emc.html
I may have to go with the good instead of spending 50 dollars on a roll of tape. :P
How much gap is there?
You can do a foil using a piece of copper from a pipe: Cut the pipe to have a square flat piece. Then, use a big and flat hammer (and a lot of time and effort) to reduce thickness till it matchs the gap.
I've did it on some P60's.
Or I could get a peice of copper sheeting. :p
Depending on the gap. If the sheet matches thickness, then it's faster and easier :P
Yeah that will work too. OSH sells copper sheet stock that you can cut easily with tin snips. Maybe 3-4 wraps with that will fill out your air gaps.
