The people who like the C8 say the L4 is ALOT better…
I like my C8…didn’t want to drop the $$ for an L4 (my wife is watching……. )
If you want a VERY good introductory rig…the C8 is a GREAT place to start…later on upgrade
With a few basic mods you can turn it from a good rig into a VERY good rig
(copper sinkpad, thicker emitter wires, solder braid tailcap) but in stock form it is quite good
Then keep an eye out for a convoy L4 deal. The most recent was $25 I think, and a few months before that wallbuys was handing them out at some ~$17 (when I got mine :bigsmile: )
The major difference between the l4 and c8 is build quality.
L4 has a solid/integrated led shelf. It has screws that secure the stock copper board onto the shelf. Very good thermal management. Then it has the side switch for mode switching and tailcap clicky for on/off.
As far as output goes it can be a bit of a toss up, but not being able to recall actual data… I would guess stock L4 will beat a stock C8 and will likely maintain the greater output for longer because of the superior thermal management.
If you had them side by side you probably couldn’t tell which is brighter.
I don’t really want to spend $28, but if its a lot better than the others, I will
[/quote]
Wait til you spend a couple of months here…. :bigsmile: $28 will seem like small change…
Welcome.
The fast tech convoy is great quality, can’t comment on the others, but if the quality of the bang good c8 is the same,I would go for that one….
