Please help with driver
Hi guys
Try to repair the driver of my flashlight (Ultrafire WF-500 6xR5) works operating modes, but without power, LEDs light up but moonlight :~
I tried changing the capacitor, but unchanged… measured the mosfet seems fine, can someone tell me which part may were be the problem?
Any help, of course grateful :slight_smile:
Many thanks
I know when I was asking these questions on buck drivers, Wight pointed me to the mosfet and the schottky as the most likely to go. I would drill a hole in it myself and make it dd to the emitters xd One mode- blind
http://www.datasheetarchive.com/dl/Datasheet-016/DSA00287549.pdf
http://www.datasheetarchive.com/dlmain/Datasheets-17/DSA-323419.pdf
Could order those parts and it might fix it.
Hi
Thank you very much for the info, I’ll check those components :slight_smile:
Hi fellfromtree
You were right! was diode schottky :wink: problem solved
Many thanks for your help :slight_smile:
Good job folks. Any idea what killed the Schottky?
Thanks, I do not know… it had loaned to a friend, I think put the batteries in backwards :~
