I’m searching for an EDC light 30$ max with a floody beam. Preferably one with zoom/flood-to-throw mechanism.
What would be important to me:
- small, uniform size, not a bigger head than the body
- floody beam, a perfect circle without any hotspot would be perfect if such a light exists
- at least a high and a low mode
- uses one AAA rechargeable battery
possible to carry it on my keychain
I have only found the Led Lenser P2 matching my specifications.
But i’m not sure about the quality and the light output of this light, because of its old emitter.
Something like the Sipik SK68 in smaller size and better build quality would be awesome.
Any help and alternative suggestions would be much appreciated. Thanks in advance for any input.
You won’t find a flood to throw that goes on a keychain most likely. Ive seen a few but they are quite rare. The F2T mechanism takes up space and is kind of fragile. I cant remember where I saw one…
That Led lenser is over 4 inches long! Thats not keychain territory. Id avoid their lights due to extreme cost for outdated lights.
If you want it as a worklight, you will have to settle with a 1xAA version (or maybe 3xAAA). These are still pretty small and should easily fit in your pocket without causing discomfort.
Romisen lights at Shiningbeam.com are pretty good. 20 bucks or so and you can check out their flood to throw selection. They have pretty modern emitters in them. This is my recommendation.
You could also give up on the flood to throw thing and go with a 1xAAA keychain light twisty. There are lots of those available. check out goinggear.com under flashlight, check 1xAAA and see what all they have to offer.
It’s definitely the smallest AAA that I own, much smaller than my Thrunite Ti or Fenix E01.
Perfect flood. No hotspot at all.
0.24 and 25 lumens
Yes.
Yes.
Nope. (Actually, this line surprised me as it didn’t fit the rest of the criteria that you outlined above.) The Preon P0-SS is nothing at all like the Sipik68. It’s much smaller and more elegant. And not a zoomie at all. If you are looking for throw, stay away. The Preon P0-SS is simply the smallest, floodiest AAA light that I’ve ever seen.
Sorry for answering so late. My Keyboard is currently not working, so writing is a real pain.
Thanks for all the feedback, sadly there seems to be no real zoomie with 1*AAA around.
The Fenix, Preon and Thrunite seem to be nice, but i´ve bought a Trustfire Mini instead, because of the missing zoom of the alternatives.
I use DCfix for making the beam more floody and the Mini has a nice lightoutput and the size is ok for me. (i use a carabiner to carry my keychain)
I ordered a Nitecore NL166 16340 hopefully it will not make the Mini explode .
Like a modified maglite solitaire? Sounds nice but at the moment i’ve spend alot on flashlights :bigsmile: . But for the future why not.
Are there any quality 10440 cells available though? Like Sanyo or Panasonic ones with PCB?
$30 CONUS is what I charge for a solitaire with the brass bling ring but it’s not really needed. The parts are emitter, lens, cell, a couple 7135’s, a bit of nylon tube, copper, and Fujik. All together less than $15 plus the host. The pill is the hard part. The rest is a few minutes work. XP-G2 is rated close to 250 lumens @ 700mA so otf should be better than 150. Don’t know of any quality protected cells as only the cheap ones need the pcb. TF 10440’s have the circuit but I can’t recommend them. I use the Efest imr cells and like them. If a protected cell is used, then the tail cap and spring should be shortened.
Um, that makes no sense at all. Different modes simply increase the amperage going to the emitter. It wouldn’t change any of its lighting characteristics.
