- 18650 - Samsung 35E (3500mAh)
- 18650 - Samsung 30Q (3000mAh)
- 18650 - Sony VTC6 (3000mAh)
- 18650 - LG MJ1 (3500mAh)
- 21700 - Samsung 50S (5000mAH)
- 21700 - LG M50LT (5000mAH)
So, If you had to limit yourself to only 2 models of cell for every use, which from offered above would you select?
Option you select will be used in any device you own that is mainly using 18650 or 21700 cells*. It can be low or high drain device, it can use one or multiple cells.
You are basically selecting 2 models that will cover all your needs.
*For the purpose of this poll let’s assume that all those flashlights and other devices that are using 14500, 18350, RCR123 and any other Li-ion 4.2/4.3V battery can also use any of the cells from the list.
Thanks for participating.
