I recently built a Convoy S4 for a friend, standard Nanjg 105c, anyhow I get a call saying the light won’t go on high?
So I go have a look and the light is actually changing modes but High is very low, low is ultra low and low is a perfect moon mode, strobe also low.
First thought flat battery , swap for new battery , same problem , measure tail current and I’m getting next to nothing on the meter, checked that the pill has still got a decent negative path.
Replace driver with a new Qlite 3Amp from IO, luckily the drivers arrived yesterday so I had spares.
Anyhow same problem after driver swap, Unfortunately I’ve no other XML in my stock.
Anyone else concur I’ve got a semi blown XML Led?
What is the resistance through the tailcap? Same issues when removing tailcap and completing the circuit with a "Insert name of nearest metal object that can short batt neg and flashlight tube, here" ?
Thanks, but read above, I measured tail cap current , very low on high, same with shorting out as described.
If I’m up to it I might take an emitter out of a Roche to test today….
Thanks , My connections are fine as all the modes work fine just at a reduced rate,and the light has worked ok for sometime , I suspect my friend left the light on high for too long.
I’ve also removed the emitter and direct connected to a 3.7v source and the led shines very low
My guess it’s kaput?
To answer all of the above, the led was tight against the pill, I built the light myself.
Led is pristine like new no discoloration at all and through a 50x magnification I can’t see any legs missing or broken.
Last I fired up the bench power supply and applied 3.6v to 4.8v and it’s easy to look into the light so just above moonlight mode, current draw the needle doesn’t even move.
Light does get brighter as I increase Volts.
Me thinks it’s Kaput, Thanks For all the replies above.
Place a piece of metal on the stove & put the led star on top. Med to med-high heat. You can poke the solder with an unbent paper clip to check when its reflowed. It also gets shinny.
Remove from heat with pliers.
It sounds like your LED is ~toast, but it’s possible there’s some fault on the mount. Reflowing would fix the heatsink joint, but the LED base itself could be weak. I’m assuming you resoldered the LED leads on both ends… I had one with an old-fashioned “cold solder joint”, which took me aback. (EDIT: I just re-read the OP and noticed you’ve already changed the Driver ends. Sorry…)
If you have a DMM, you could try to check Continuity through the LED itself. That should get you a little bit of light. Just touch the solder pads on top of the LED, not the heatsink. If it doesn’t light up, switch ‘+ ’ for ‘- ’ and retry. If that works, retest on the heatsink solder pads. Different? Reflow. Same, Re-place! If you’re really still, you might be able to measure R between the heatsink ‘- ’ and the LED ‘- ’ and vice-versa. A non-zero R shows your Root Cause.
Also, did you direct-connect to the LED solder pads or to the heatsink ones? Either way, why not try that again with a DMM in Current mode inserted in one lead? This gives you Iled, which is all the XM-L cares about (keep your Source under 5v). That’s a useful troubleshooting data point.
I’m scratching for outliers here, and would “+1” the idea of just ordering a new XM-L for three bucks…
When you do, don’t you have to be very careful to hold it w/o wiggling or tipping? This “trick” would be the only way I’d have to reflow anything, so I’m curious. Also, do you cool it in any significant way after it gets “shinny”?
I was thinking it might be useful to have a cool, wet sponge or paper towel handy…?
I haven’t had any trouble when moving it off the heat. The surface tension of solder provides some resistance to movement. Just let it cool on its own after removing from heat.
I’ve actually used a food thermometer to keep an eye on the temp and prevent overheating.
Spring tweezers are much better then pliers only $1.20 on ebay. The edges aren’t rounded so they aren’t the most comfortable, a little filing fixed it.
Ok applied 4 volts direct to led same thing low power, I then re flowed the led off using a butane torch and basically fried the sink pad , too much heat …haha
But led came off and now is totally kaput.
No I know how not to reflow ….hehe
Got some new XM-L2 in the post so no worries , light will be up and running again with a brighter emitter than before and a Qlite 3A driver too.
