I tried searching around the forum, but didn’t get any luck with results.
I bought a zoomable Trustfire Z5 recently, unbeknownst to me, the supplier I got the flashlight from, their Z5 didn’t come with memory mode. So every time I turn on the flashlight, I have to click through, until I get back to high.
I am aware of the possibility of ordering a new xm-l t6, one that comes with memory mode ability already manufactured into the chip which is what I’m going to do in the future, but I was wondering before I solder off the xm-l t6 chip from my flashlight, is it possible to solder off the modes from the flashlight, only to leave high-mode? I’d rather have the flashlight turn on in high-mode any time I push the button, rather than have to scroll because of lack of memory mode.
Is this within the realm of possibility? Are there any search terms I should search for specifically in this forum, to point me in the right direction of disabling modes off my flashlight xm-l t6 chip?
yea you’re looking at a driver replacement. Basically not the Led chip but the electronics on board it. I’d say if you’re not too good with eletronics & soldering and the flashlight you bought wasn’t too expensive just buy another. Say 40 bucks would get u another with the things you want. Cuz the drivers are anywhere from 10-20 dollars. It’s all up to you. I’m sure there’s more people more experienced on the forums to answer this than me.
The XML T6 is the LED. It has nothing to do with modes or mode memory. That function is performed by the driver. You will need to replace the driver with one that is compatible and has the features that you want.
It’s not the XM-L T6 chip (known as “the emitter”) that gives the modes. Rather it’s the circuit board (known as “the driver”) that’s mounted behind the chip.
Depending on what driver is installed, it may be possible to use solder bridges to get rid of the blinky modes or make it a single-mode light. You can even bypass the driver board entirely and run the light in direct drive. Another option is to replace the driver with a different one that lacks the blinky modes.
Since modes are governed by the driver, buying a new XM-L T6 emitter won’t affect the modes. You’d still be stuck with the blinky modes.
With some basic electronics knowledge you can convert a multi mode light into a single mode light easily.
Multi mode drivers usually have an 8 pin microcontroller to adjust the Led brightness via Pulse Width Modulation. This is usually through one output pin of the MCU and this output drives a MOSFET, another IC or a set of AMC constant current drivers.
First thing is to find the MCU on the driver board. They are usually ATTINY or 12F629 written on them. If nothing is written it may still be one of them or a copy. Now find the line through this MCU to the driven elements. This shouldn’t be much problem as after finding power lines there should be one or two line left already. Use a 220-470 ohm resistor to short this line to VCC (+ supply) try if modes are gone. Try GND (- supply) if shorting to VCC doesn’t work.
Since we only set the PWM line, this method shouldn’t cause any problems like direct driving.
