Possible safety concerns.. Advice please
This is a picture of the tail cap of a Lux-Pro LP470. I have done this at ;east 10 times for friends and when I finally decide to do my own, I cracked the plastic.
That light will run easily with an 18650, get about 50 lumen extra and much better battery life verses the 3 triple A's. Every one I have done this very simple mod all that was necessary was to tighten the plastic ring on the tail cap and be sure to use a protected cell.
As you can see my own cracked, actually just that little chip. Believe it or not it still works fine, even the mode changes.
From a safety standpoint should I just chalk this one up and trash it.
It's a decent and easy mod current goes from .70 stock 3 tripe A's to over 1.5 with just a battery swap. The Cree XP-G2 R5 can easily handle it. Just not sure about the chip.
All advice is welcome and much appreciated.
Can you describe what you did again, and get a focused picture? I’m not familiar with that light and I can’t tell what I’m looking at.
EasyB, if I’m seeing it correctly the chip is seen at the 10:00 position relative to the brass contact. What we’re seeing is the inside of the tailcap.
Is this the light?
If I understand how, in general, these lights work, the tailcap makes contact with the neg end of the cell and sends the juice through the body of the light to the electronics at the head of the light. That’s where the positive is found that can get you into trouble. So what you have near the chip of concern is nothing but negative “juice”. The positive that could get you into trouble is at the head of the light. You know the internals of the switch since you’ve replaced others. Is there anything in there that can get up to the head of the light and short out things out? If the space between the cell and wall of the light is filled with something parts probably can’t migrate up there. But the tube is larger than the body of the 3 AAA adapter so it would need a piece of PVC pipe or some such.
IMO, it’s probably not possible for the above to happen (if the space is filled) so I think you’re OK to use it, and if it fails then it’s time to replace it. But I surely wouldn’t trust it. I’d have a spare light with me for when it does fail. OK, having written that, I wouldn’t have a light with me that could fail because when I need light I need light. So I think you’re OK, but I wouldn’t have it. I’d fix it or junk it. But it’s your choice, not mine.
Assuming filled space between the cell and body, if it fails you’ll just have a switch that no longer works and maybe negative juice still going to the light body via a different path. When you open it up you’ll have a few parts in your hand.
Folks, if anyone needs to whack me about the head and shoulders for giving bad advice, go ahead and do so.
Just curious, are the light parts plastic? I’m curious as to how this could happen with aluminum parts. If I found the light (see the link) I don’t see where it says what it’s made out of.
You are correct... the light was very inexpensive so buying another would be worth not having the worry.
I still can't believe after doing so many for others it turns out to be my own.
Maybe I will treat myself and spend a little money. I still have 2 Latticebright fake Ultrafire's that I want to install real Cree XML's. I want the latest version and boards. I think I measured 20mm.
Any ideas where to order and not have 30 day shipping. Gonna put this one to rest... Except for parts lol
It is a Cree.
Thanks very much.
>tighten the plastic ring on the tailcap
Is this because the li-ion cell is slightly longer than the 3xAAA battery holder?
Can you trim the spring instead? (and smooth/bend the cut end so it makes smooth contact and doesn’t gouge the battery)
When you replace a 3xAAA holder with a li-ion, you need to fill the space around the cell
https://www.google.com/search?q=3AAA+li-ion+battery
You can do that with a piece of plastic tubing, PVC pipe is available in the size you need, hunt up a scrap bit.
From the (blurry) photo looks to me like you could just fill the hole with some epoxy, or epoxy the chip back into place if you didn’t lose it.
Enough to keep the spring from being bent sideways into the gap, if that’s the concern.
Or find a thin washer/bit of plastic with a small hole to fit down over the spring and cover the opening, or both.
I also need a 600 or so lumen rugged enough for work.
The chip actually pretty much turned to nothing. I was thinking an epoxy fill too. I actually need to order some 18650 plastic sleeves. I had about 20 and yet somehow now I have 2.
And you are totally right I should have just trimmed the spring. The others I did were very simple to just screw the ring on the tail cap a little tighter and it fit almost perfect. My light was a good deal older. Spring should have been the way to go... Live and learn. Honestly I knew better, kind of makes me mad at myself.
My job. Fix things the right way the first time. No short cuts and no half ass repairs. So I know better.
You could get a C8 for just a few more dollars. But if you want rugged I’d try to locate a plastic lens for it. Might get a few while you’re at it. I used a SL4 at work and over time the heat from the bulb would blister the plastic lens. I think the build quality of the C8 will be much better than the broken light.
Try Mountain Electronics. There are probably other sources here in the US and other proprietors who are on this forum. I only know of Mountain off the top of my head though. When buying a C8 one must be careful of counterfeits. I know, I got 5 of them from TMart. They made good on them each time, but it got tiring after the 3rd shipment, and the ones I thought were OK pooped themselves after a bit. Mountain has the real deal with no fartin’ around.
jC8 is a great light but a little big for my job. I'm a technician and spend half the night under, on top of,insode needlepunch machines. I have a sk98 I take when I have to. But it's a real Ultrafire so I try not to use it too much there.
The only other lights I can think of don’t use 18650s (would an s2+ be too floody?). But my experience is quite limited. I’m sure others will have suggestions.
I did much the same thing for my last 8 years before retirement but in a different industry, I found a headlight to be of value when I wasn’t using my handheld. Mine didn’t use rechargeables though. Today I would have a much different headlight than what I used back then.
I don't have any problem with the light using an 18650, I have plenty of those that need something to do. It was more the size of the top (reflector) it really needs to be able to fit in a pocket. I normally wear Carhartt pants to work so I have several pockets to choose from. Even 500 lumen would be okay. I do need it to be able to zoom. Flood and spot. I also take my Ultrafire C3 alot and it really does very well. I just need a little more light.
Oh.. I almost forgot. I just got home from Lowes (by the way they sell almost no soldering supplies anymore). I know we have a Lowes thread and I will post it there too as soon as I find my receipt. I was buying some wire by the foot and come to find out they are doing away with at least the smaller gauges selling by the foot. All of the gauges 20 down to 10 is a penny a foot. You read that correctly 1 cent per foot. If any is still left when I get off work Saturday morning I am buying all of it... Check you local store.
