this is a preliminary review. due to weather (snow\fog\light pollution from sky) i cannot shoot any decent outdoor pics to illustrate throw. when weather changes, i update review with these pics. u can find them in other author`s reviews, if needed.
I got my hands on an unusual hunting flashlight for gun mount. Manufacturer is new, but they accepted challenge of creating biult-in color filter. Let`s take a look if Cyansky succeeded in this or not.
Specifications
- Battery:1*21700
LED 12V XHP35 HI
maximum brightness: 1300 lumens maximum range 400m (40,000 cd)
Colors: white, green and red
size: length 16.71 cm / 6.57 inches
head diameter: 4.14cm/1.63”
body diameter: 2.39cm/0.9”
Weight: With Battery: 240g / 8.4oz Without battery: 166g / 5.9oz
Package and appearance
The flashlight is well packaged. Design is not astonishing, but, overall, it is not cheap. You feel that it is brand flashlight just when you hold it. For example, I have a guest yesterday, quite experienced dude with lots of flashlight in collection. So i showed him H3, first that he said was “machining is flawless, feels really good”
I was really pleased to see runtime charts here. That is not that often met feature that i highly evaluate as sign of honesty from manufacturer.
but i must notice that brightness scale here is presented so cunningly that the thermoregulation saw seems insignificant, and the High mode seems to be really close to Turbo, unlike it is in reality.
The kit includes everything u need, and even more - namely a spare tailcap button. By the way, you also can buy a remote button.
Lanyard is reeally good. Exactly the same as top Fenix flashlight have. But the golster is frankly modest.
Design of the flashlight is modest as well. There is no complicated and attractive knurling. However, Cyansky H3 appearance is peculiar enough to stand out from the crowd of other models.
Modesty in design is balanced by indiscretion in size. The flashlight is frankly rather long, which is not an advantage for a gun-mounted flashlight. 16.4cm body length is qiote a lot.
The tail button is direct click power one, with ease access to it.
Full click makes sharp and loud sound, not a good for hunting.
The spring is good. I note that it is not bypassed in my review example, unlike new batch of H3.
Promotional picture promises dual spring, which i a must for gun-mounted flashlight to withstand recoil.
In reality, a single coil of spring is simply soldered to the driver. Looks like this was done in order to make H3 store long 21700 battery, the one with biult-in charge module.
Here he is by the way. It charges quite quickly, in just 3 hours. Good, good.
No spring at head is really uncool for gun-mounted flashlight. I`ve hit H3 several time really hard, the contact at head wasn`t broken, light didnt turned off.
But the question is not contact itself, but that battery bay just crack driver as there is no amortisation at head. I dont say it will happen, but it may happen when there is no spring at head.
For some reason, there are no usual knurling: “pineapple”, square or there is a classic small rhombus. Instead, there are just flat cheeks on flashlight body.
Taking into account the fact that the body is smooth here, and there is no clip, i dont feel like the grip is firm. So, using holster is a must.
Nevertheless, the grip itself is comfortable, because body is quite long. Believe me, longer flashlight is way more conveniend then shorter one with no place to put fingers on.
The head seems to be quite massive, but that is normal size head. It just seems to be large, becayse body is smooth and long. In reality it is the same as Sofirn C8G has.
The side button here looks extremely simple. Fortunately, it protrudes strongly enough to be easily felt even with winter gloves. Quite peculiar design, but i dont feel any incovenience with side buton.
Here you can clearly see the ring which changes color filters. I dont feel it is mechanic, suppose that is magnetic switch. The ring moves smoothly. Gring move has a gap of a couple of mm, but it does not interfere. There is no visible gap between ring and body.
The teeth of the bezel are wide, but quite high.
And here is the most interesting. So, at the bottom of a sufficiently deeply textured reflector, a dedomed XHP35 LED is installed. And a “kaleidoscope” of color filters is installed above it.
You can see how everything is organized inside. Well, quite unusual.
Two slats on the sides reveal a spring with a ball at the end. When you select the desired color filter, this ball enters the grooves, fixing the selected position of the ring.
It all looks just freakin awesome - like some odd-eyed Michelin man. Pay attention, it’s not just glass of color filter, but a small reflector under it as well. And on top is already the main large reflector. That a damn precise machinery, not a cheap OEM stuff from unknown basement.
UI
Extremely simple and understandable to any user without a manual. This is good.
But such simplicity means that you can forget about instant access to Turbo mode, which is bad. U can instantly reach Turbo only via modes memory, if turned flashlight off in this mode.
In short, the tail button is OFF-ON, the side button changes the brightness of Low-Mid-High-Turbo by pressing
When you press the button, the strobe is turned on, which is undoubtedly very “necessary” for an underbarrel flashlight. I definetely would prefer shortcut to turbo mode by button hold.
In general, if you need to turn it on and shine, then it’s fine.This works really well for thousands of simple users. As well as this is way too primitive for less number of experienced users.
Cyansky H3. Runtime and Light
The flashlight is well stabilized. 450 lumens is frankly a very modest brightness for High. However, this brightness (in white color) is enough to work within a hundred meters.
The flashlight is really big and could easily handle a much brighter High mode.
It could, but it can’t. The same 1300 lumens of Turbo mode is, again, a fairly low brightness for a flashlight with such dimensions. And the LED itself can work with no problems at the level of 2000 lum, there are bunch of XHP35 flashlight with this brightness in Turbo mode.
OVERALL IMPRESSIONS
Cyansky H3 is a rather unusual flashlight, which has a lot of CONs and PROs. As lots of other flashlights, actually.
It is positioned as a gun-mounted flashlight for hunting. This is an activity I have nothing to do with. So do not expect that I will be able to reasonably evaluate it`s usefulness for exactly what it was made for.
However, review experience still allows you to make some objective pros and cons.
PROs
-> Cyansky is a completely new brand, known only in narrow circles of flashlight forums. It was all the more pleasant to see that the main and most complex functional feature of Cyansky H3, namely the “carousel” of color filters, is far from being primitive construction. Let me remind you that there is a small reflector under each filter, there are grooves for a spring-loaded lock of the position of the color filter selection ring. Functionally, it’s really convenient. Everything is nice and neat at the head of the flashlight.
The choice of color here is actually convenient and I strongly welcome the possibility of this choice in general. The other flashlight supplementary light I’ve seen is Brynite Artemis, was is one of worse brand flashlight i`ve ever seen. Worst is Brynite Apollo, btw.
-> The light distribution here is quite pleasant. You have some reasonable throw and suitable sidelight. Not really much, according to modern standarts. But still good as is.
You can count on good light within a radius of about 300m until turbo drops. This is much more than needed for a smoothbore gun as far as i know.
-> The light itself is stabilized, with a long runtime, thanks to the capacious 21700 battery with fast built-in charging.
-> Grip is comfortable. There is no difficulty in finding the side button. The manufacturer optionally sells a remote button.
CONs
-> The flashlight is no compact at all
-> The grip is not particularly tenacious. Clip would really help here. But there is no clip.
-> As well as there is no spring at the side of the head, which is frankly strange for an gun-mount flashlight.
-> Tail button is too loud
-> 1300 lumens of maximum brightness is frankly way less then you can get from XHP35 LED.
As well as 450 lumens is frankly low level to be called High mode.
-> The XHP35 has a neutral light version, I see no reason why this flashlight has a cold LED installed. May be that is XHP35.2, i`ve heard CREE doesn`t sell NW version of 2nd gen.
-> Thermal control is too aggressive. A flashlight of this size should easily sustain 1000 lumens without cooling.
Here, the brightness drops from the turbo drops to 65% (i.e. 850 lumens) and the flashlight cannot keep even this brightness without cooling. However, most hunters said that they needed gun-mounted light for an exceptionally short period of shooting, and here the influence of thermal control should not be taken into account.
As a result, speaking of stabilized light that does not jump up and down, you can count on either 850 with cooling or 450 lumens without cooling.
-> Color filters seriously cut the brightness, especially the red color filter. Even a full turbo only delivers 100 lumens for red light (i.e. either 65 or 30 lumens of continuous light depending on cooling). With green light, however, the situation is better. Whether it’s a lot or not - decide for yourself.
The dry residue is the following. There are virtually no models with built-in color filters on the market now. The one I know, Brynite Artemis, is just awful so i don`t count it. I have no complaints about the Cyansky H3 from the standpoint of the versality of light and convenience of use as such, here the main functional feature, this built-in color filters are well implemented.
Although it is strange that the manufacturer did not increase the brightness up to the 2000 lumens that are easily achievable for this LED. I`m not hunter, so i don`t judge whether there will be any use of these color filter for the hunting.
You should not expect significant range here. Here specialized models with green or red Osram LED performs way better. But they don`t have white light.
So, if you need a moderately long-range flashlight with instant change of colors filters, I think Cyansky H3 will fit. Just because it is the only such a model on the market, there are nothing similar.
H3 would be a rather “one more flashlight” without these feature of built in color filters. They change everything.
Overall, Cyansky H3 is a specific flashlight, for specific purposes. It has PROs and CONs, and I named those that I found here. Hope it`ll help you to decide if you need this one or not.
