I’ve seen a pressure switch for a UF C2/C8 on manafont. Would the switch work for a XinTD C8??
Building a AR and thinking about light mounts, lights, and switches.
Thanks!!!
Sorry if this is the wrong section for this topic.
Thanks!!!
Might be helpful to provide a link. ;)
Here’s the switch
http://www.manafont.com/product_info.php/pressure-switch-for-ultrafire-c2c8-flashlight-55cm-p-5895
if a uniquefire c108 tailcap will fit on a XinTD c8, ill mail you mine for cost of shipping
edit: it doesnt fit my trustfire tf-r2 if that says anything… i dont have an actual c8
I would think this one would work. I have one and it fits quite a few of my lights, ie c8, jacob a60 and small sun c10 zoomie
Here is one thats a little longer
Edited these don’t have a tail cap for the light you would have to take yours apart and add it. Its easy though to go back and forth if needed
Thanks guys.
I wonder if they would also work on a 980L.
Even if it did fit and work on your C8 be care about what you mount on your rifle. The El cheapo mounts will dislodge from your rail. The tape switch works fine off a rifle. After a few clips the flashlight or the switch typically will fail if not designed with a shock absorption system. Just a few names that build legitimate purpose designed lights with excellent switch are Jetbeam, Surefire, etc..Mounts? stick with Larue, DDefense. I know its a big differnce in cost but your literally sending cheap parts to an early death on your AR. Good luck
Thanks for the heads up Darkside. The mount I ordered doesnt mount to the rail. Here’s a link for it.
One to the far right.
I’ve found one over at lighthound I may order. Cost is a little more but its here in the US.
Thanks guys!
Thats a pretty nice mount. Im not sure if it works on flip up sights but i think im
going to give it a try. Thanks for the link,
Darkside, I found that on ebay.
