A BMS doesn’t ensure a staple voltage output. It just protects the cells from overcharge and over discharge. The only way to get stable voltage output would be to go 4S and use some sort of Buck converter back down to 12v ( head spinning yet ) Most of these devices as the voltage drops the amperage will raise to keep the wattage output close to the same. The only problem I see with the lower end of battery voltage is, will the vest keep you warm enough. All this stuff takes trial and error.
To me if you are not familiar with this stuff, you might want to buy a prebuilt battery pack ready to go. There’s plenty cheaper ones to choose from
