My leads are acting wonky, so I want to build new leads. I have some extra 12 awg silicone wire that I want to use for this.
Should I put plugs on the end so I can swap out clips or probes, or is the additional connection resistance going to be significant?
Alligator clips are starting to piss me off. The insulating shroud slips around way too easily. Insulating clips on multimeter leads isn't nearly as important as with the leads of a charger, but I'd rather have the protection just in case they bump into something they have no business touching...cramped work space. :(
These removable clips have a molded shroud that should be easier to grip, and looks like it'll be more protective. And they claim it's copper. Those particular clips might be too big, but I've seen similar smaller ones...it's just an example of the style. There's also this style of removable clip. With either one I'll have to figure out what kind of plug it uses. They could be replaced with these probes as needed. I have concerns about burly 12awg silicone wire fitting into that handle though, and the wire itself might not even fit into the probe. What if I solder some solid copper wire into a plug and wrap with heat shrink? Any reason that wouldn't work well as a probe?
This Mueller clip doesn't have insulation, but the clips itself looks like it'd be easier to grip. It has a screw that can press the wire down during soldering, and hopefully reduce some resistance. Since there's one less plug, there should be less overall resistance. It also claims to be made from copper. There are different sizes, so again, just look at this for the style.
