problem with my SKYRAY 3xT6
Hi guys
got my 3xT6 today and was delighted for a few minutes
it will not run on med or Hi for more than 1-2 minuets before shutting down
i have done all the usual cleaning and tightening and have tried 3 sets of batteries
(1 set gray ultrafire 1600mah ) ( 1 set ultrafire blue 2400mah ) ( and 1 set trustfire 2500mah )
all batts fresh from charger and reading 4.1v-4.2v
if i let it sit a few minutes it switches on but only for 1-2 minuets again
the batts are warm but not to hot to hold in my hand
all the batts are a year or two old
i will order some new batts any thoughts on whether it is the light that is faulty or the batts that are not up to powering this light
cheers Barrie
I think it may be the circuit protection in the battery, that is shutting it down.
Try unprotected ones. How many amps does it pull for the 2 minutes?
Hi mate
i have tried 3 different sets of batteries only the 1600mah ones have a protection circuit
it is doing it with them all
just put the multimeter on
it is pulling 263-267 Amps on High for the first few seconds then starts to go up steadily until it gets to 4,40Amps then shuts off Surprised
have i missed something obvious i am no electrician
surely one of you friends have a idea
I cant help with any good ideas but I'm here for moral support. Did you try unprotected batteries? I guess that would only point you in the direction of the problem though.
Measure voltage. Its prob your batts. I have 1 set which is just like average, it powers other lights ok like UF U-80/UF-980 ok. In this it will just ramp up the current when voltage goes down, and if the cell is just merely average the current would shoot up as the regulation circuit tries to compensate. Then its either the protection circuit in the cell that cuts in, or the voltage sags so much that the driver voltage protection cuts in.
Do this test, do a current reading at the tail for a couple of minutes till it shuts off. You could see that it goes from say 2.9A to as much as 3.8A. From 3.2-3.8A it probably rises pretty fast within 10s. This means the batts are unable to provide the juice. You see the phenomenon of it able to come on again after rest coz it has recovered, then the same thing will happen again.
Ahh...mystery solved. 4.4A, too much for your cells, even if they are unprotected the voltage probably sagged and the driver voltage protection kicked in. Charge them up first, match them (which is very important, 1 lousy cell spoils the whole show), and see if you get improvement from say 5 min to 15 mins.
Good cells to use include Solarforce V2 18650 - 50 mins run time on high.
Panasonic NCR18650 2900 - 60 mins. Get from HKequipment for 19.90 shipped for 1 pair. Same stuff as Redilast or AW but cheaper. These are unprotected but the driver will protect it and it works every time.
Hi Max 2600 should work well, get 6 and its cheaper. (Ebay)
One last thing, if you are getting that "current suddenly shoots up from 3.0A to 4.x amps" reading, 100% its the batteries that are incapable of providing the juice. They still work in other lights, just not this puppy.
Test the rear switch by removing the tailcap and connecting the battery to the body with a piece of wire (paperclip, whatever). I had a similar problem with my WF-502b, and it turned out to be a bad switch.
(my symptoms were basically the same, but mine only went for a minute or so until shutoff. on partially discharged batteries, however, this problem disappeared)
Edit: Everyone elses answer makes more sense... my diagnosis just involved tinkering 'til it worked.
thanks my friends
all is pointing at the batts so i will order new ones
thanks for your help
cheers Barrie
You scared me for a second there scruffy. I am still waiting for mine. I plan to use only xtar 2600 in mine.
hopefully you will not have these issues if you have good cells
i hooked my light head up to 6xAAs in a 6xAA to 2D holder that i bought from one of the custom bulders over at the other side
it ran with no problems
Glad to hear that it is due to the battery. It is a happy problem, that means the voltage protection is always working....perhaps set a little high, but its for the general good. Smile
I had the same problem with my specimen. I found out, it was the contact between the end of the battery tube and the pill. There is a threaded ring which holds the driver board in place. It has a spring underneath, so there is no problem to losen this a bit (a half turn) to get a firm contact to the tube. Well, this fixed the problem in my light. Give it a try, it's cheaper than new batteries.
i got new batteries and all is well i get 40-45 minutes of continues run time on high Cool
Hi.
I've just ordered the skyray 3800 lumen from ebay. came with 2 ultrafire 18650 batteries. I'm having the same issues as described earlier, after less than a minute on high it turns off etc. Is it the batteries that are the problem or a faulty connection?
Hi.
I'm having the same problems with my light. Don't suppose you could help me out?
Are they the blue Trustfires?
If so, you likely need better cells. This light draws a lot of current.
EDIT: Welcome to the forum, some dude.
they're are the red ultrafire ones. I was planning on sending it back and ordering different light. are there any lights with equal power as this one but still cheap that you could recommend?
thanks
Some-dude, the problem is with the batteries. Even with a single XM-L light but driven at full power, you might have an issue if it has low-voltage protection. Ordering another light probably brings you back to square one.
You can order the XTAR 2600 batteries, they are supposed to have Sanyo cells inside. Very good and safe stuff. BTW for the light, try not to gun for over 10 mins, the LEDs can take it, but not the driver. If it's very cold in your country (below 5 deg C + slight breeze) you can try for 20 mins.
https://budgetlightforum.com/t/-/72497
