HELLO Everyone,
Welcome to our store
These items have discount now:(1) CANTOO Cree XM-L U2 LED 900lm 5-Mode Zooming Bike Light/Headlamp (1 x 18650) Free Shipping
(2)TrustFire TR-DF003 Flashlight CREE XM-L T6 LED 35W 3000LM Diving Torch (2 x 26650)
Technical Parameters:
1. With three US.CREE XM-L T6 Led lights, brightness 3000ML, led life of 100,000 hours.
2. Intelligents control circutis, five-speed memory dimming circuit, convenient for user to change modes at will.
(1) High: current 4500mA, brightness 3000LM.
(2) Mid: current 2000mA, brightness 1500LM.
(3) Low: current 450mA, brightness 300LM.
(4)Strobe: current 2000mA.
(5)SOS:current 4500mA.
3. Vsvuum plating smooth cup, high temperature resistance, anti-fall concentrating the effect perfectly.
4.Shell aviation aluminum,CNC matching, anodizing surface treatment.
5.the lensusing PC engineering plastic, preventing the lens to brust more efficiently.
6.With two 26650 lithium battery with protected circuit board, continuously using 2 hours.
7. Specifications:233mm(length)X68mm(head diameter)X39mm(body diameter)
8. Special design for military, law enforcement, self-defence,hunting,outdoor,search,rescue and other special design,waterproof
ability according to the standard of IPX8, 100M submersible.
(3)CRELANT C-M5
Specifications
- CREE XM-L2 LED with 50 000 hour life span.
- Maximum output: 680 lumens
- High efficient constant current circuit and output-luminance
- Tactical High Mode, and On side switch Infinitely variable brightness system
- Hidden Strobe and SOS, Quickly click 2 times side switch ā-> Strobe ,
and quickly click 2 times again ā-> SOS
- Working voltage: 2.7Vā6VDC
- Battery Types Supported: 1 x 18650 (Not included)
- Runtime:High output: 100 minutes.
- Mil. Spec. Type III hard anodized aircraft grade 6063-T6 aluminum alloy
- Color: Black
- High performance aluminum smooth reflector with concentrated beam shot
- Waterproof: IPX-8 Standard
- Lens: Toughened ultra-clear coated and anti-abrasion glass
- Dimensions: Length 155mm, Head Diameter 36mm, tail diameter 25.4mm
- Weight: 155g excluding battery
- Accessories: Lanyard, spare o-ring.
